Transmission Yoke PN?
Old May 16, 2017 | 10:50 AM
FORD~'s Avatar
FORD~
I've a 2WD 1973 F250 (390 C6 133WB 3.73 Dana 60). I managed to find the right driveshaft slip yoke. Now I am trying to find the transmission yoke part number.
Can anyone help? Or point me to what section these are listed in the '86 Master Parts and Accessories Catalog and I can look it up myself? It's kinda hard to navigate that catalog from the wiki.
Any help would be much appreciated!
Old May 16, 2017 | 10:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by FORD~
I've a 2WD 1973 F250 (390 C6 133" WB 3.73 Dana 60). I managed to find the right driveshaft slip yoke. Now I am trying to find the transmission yoke part number.
Does your F250 have a 2 piece driveshaft?
No such thing as a 1986 master parts catalog. Parts for your truck are listed here:
1973/79 Ford Truck 100/500 (series) Parts Catalog (available on a C/D from hipoparts.com).
Includes F100/150/250/350/500, Econoline, M450/500 Class A motorhomes & P350/500 (P series Parcel Delivery).
Old May 16, 2017 | 11:17 AM
FORD~'s Avatar
FORD~
I am just going by what is listed at the top of this page:
FordPartsWiki - Master Parts and Accessories Catalog FPS 8096-A October 1986
(Master Parts and Accessories Catalog FPS 8096-A October 1986) I suppose it's incorrectly listed?
Yeah, it's a two piece driveline (133 wb)
I'll find the tranny yokes. I just have to keep pecking I guess. The wiki interface is terrible.
Cheers.
Old May 16, 2017 | 11:33 AM
NumberDummy
This is the 10/1986 edition of the 1973/79 Ford 100/500 Truck Parts Catalog.
The C/D version was scanned from the 4/1980 loose leaf paper edition.
The final edition was issued 10/1988. I have this on Ford microfiche slides.
Look at this parts catalog pic of the 2 piece driveshaft: Illustration Section 46, page 3 (1980 C/D version).
To get the trans slip yoke, the #4817 coupling shaft (front driveshaft) has to be looked up.
Two piece driveshaft has 3 u-joints (front/center/rear) and a slip yoke between the coupling shaft and the (rear) driveshaft.
There is no other slip yoke, the driveshaft rear u-joint attaches to the companion flange (#4851 in pic) of the rear axle.
Old May 16, 2017 | 11:39 AM
FORD~'s Avatar
FORD~
Thanks sir. That will def save me time looking this up!
Old May 16, 2017 | 12:01 PM
NumberDummy
I'll save you the trouble...
D3TZ-4841-C .. Slip Yoke / Obsolete
Coupling shaft parts list #8: 1973 F250 2WD 390/C6 133" wheelbase; ditto 1974 before serial number T80,001.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 19 = 800-476-9653.
Old May 16, 2017 | 12:27 PM
FORD~'s Avatar
FORD~
Ah good! I found "D3TZ 4817-AH driveshaft coupling assembly"... Rookie parts man pilot error here. haha
Thanks again.
Old May 16, 2017 | 12:28 PM
HIO Silver's Avatar
HIO Silver
A C6 slip yoke is available from Summit Racing.. about $90.
Old May 16, 2017 | 12:30 PM
FORD~'s Avatar
FORD~
16 spline and 1330 ujoints? I tried Summit but found nada. I will take another look.
Old May 16, 2017 | 12:44 PM
NumberDummy
D3TZ-4841-C .. #1330 u-joint, 31 splines, it's a tiny bit over 6" long. This is the only front slip yoke for your F250's application. 20 are available NOS .. listed in post #6.
The slip yoke between the coupling shaft and the driveshaft is: C8TZ-4841-A #1330 u-joint, 16 splines, about the same length as D3TZ-4841-C
Old May 16, 2017 | 12:50 PM
FORD~'s Avatar
FORD~
D3TZ-4841-C .. #1330 u-joint, 31 splines. This is the only front slip yoke for your F250's application. 20 are available NOS .. listed in post #6.
The slip yoke between the coupling shaft and the driveshaft is: C8TZ-4841-A #1330 u-joint, 16 splines.
ah I have not pulled the front slip off. Just assumed it was same spline count as the rear. I ordered the ​​​​​​​C8TZ-4841-A yesterday. So at least I got that one right!
Old May 16, 2017 | 01:38 PM
HIO Silver's Avatar
HIO Silver
Anybody got a source and cost for that splined cork seal? It is under the threaded cap and keeps the grease contained.
Old May 16, 2017 | 01:45 PM
NumberDummy
There two different types. To find the part number, I need to know what you're working on, because these puppies are listed with the coupling shaft to rear driveshaft slip yokes.
AFAIK, the only source will be NOS and since it's made of cork...cork shrinks with age. So you may have to soak it in hot water before installing it.
Old May 16, 2017 | 02:38 PM
FORD~'s Avatar
FORD~
I still need the washer (B3D 4819-A)
But I ordered a pair of seals yesterday: B3D 4820-A
If that PN works for you I'll send one to you. They did look 'dry' in the picture, to ND's point.
Old May 16, 2017 | 02:46 PM
NumberDummy
CARPENTER NOS OBSOLETE PARTS has 26.
GREEN SALES CO. in Cincinnati OH has 113 = 800-543-4959.
