Door Speakers - '76 F150
Old May 14, 2017 | 11:41 PM
Highcking's Avatar
Highcking
4wd Low
I recently acquired a mostly-restored 1976 F150. One item not restored was the ancient AM radio and old dash speaker. I've already replaced the radio with an original Ford 1976 AM/FM unit that works fine ... but the speaker is shot. I'd like to go with door speakers, and I can see that the doors are set up for 5-1/4" rounds speakers. But the doors and the sides of the cowl have no openings for speaker wiring to pass through! This seems like an odd combination. Can anyone post pics of where the wiring holes should be and how large? Thanks.
Bill
Virginia
Old May 15, 2017 | 08:30 AM
HIO Silver's Avatar
HIO Silver
There should be a factory dimple on the front side of the door Jamb where the hole is drilled.
The factory offered an OEM harness... dunno the hole size for the grommet.
Thwre was a thread with pic within the last month showing the location, factory harness, etc.
Btw, the door speakers are 6.25 or 6.5 inches cuz ya gotta account for the speaker flange.
Old May 15, 2017 | 09:21 AM
HoustonDave's Avatar
HoustonDave
Do a quick search for door wiring and you will probably get a hundred threads, many recent. That seems to be one of those "beat to death" topics.
Actually the original speakers were classified as 5.25" - usedtabe speakers were classified by the outer cone size and it was taken for granted that a 5.25" cone speaker needed a metal surround which was a tad larger so you could screw it into something. Somehow that has morphed over the years to refer to the screw placement and most current speakers are actually 4 .75" speakers with little "ears" added on to reach the holes. (Me, I think you could take a 2" tweeter and add the ears to call it a 5.25" speaker and it would still be a 2" tweeter, but I'm a curmudgeon.) Lot of larger 6"ish speakers have mounting holes which fit the old 5.25" pattern... hence the overlap. I just returned a set of Kicker speakers for just this reason...they also sounded like crap, which didn't help. Next up - new head unit and under-seat sub.
Old May 15, 2017 | 05:57 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on there are threads that have the exact answers and pics you need. Advanced search is the key. NOT the search box in the middle, but do you see the blue line with User CP, Albums, FAQ? See the SEARCH on that line?
It has a drop down search menu arrow, go to the "Advanced Search" option, top left side (search block) type in there what you are looking for and then go to the lower right column and highlight 73-79 forum. Select it and then you will have a detailed search just in the 73-79 forums.
BOOM found it for you. https://www.ford-trucks.com/forums/1...s-factory.html
Old May 15, 2017 | 08:33 PM
Highcking's Avatar
Highcking
4wd Low
Many thanks for these replies. I located the dimples and much appreciate the pictures of an installation. I should have searched because there are indeed a number of threads on this topic. This is an excellent forum that I will find very helpful as I finish the restoration.
shameless
Nov 6, 2017 05:08 AM
85FordF150
Dec 3, 2006 02:32 PM
RyanSta80
2004 - 2008 F150
May 31, 2005 11:40 AM
bigbrown84truck
Aug 8, 2004 12:06 PM
luke_trash
Apr 16, 2003 10:48 PM
