2012 EB rough and bucking at high and WOT - ?
Old Nov 23, 2016 | 05:30 PM
CMOS's Avatar
CMOS
Howdy All,
I've had this 2012 for several months now but have never really romped on the throttle until yesterday's road trip (not a lead foot driver).
I was driving on the highway at about 55 when I needed to pass so I floored the throttle and - the truck bucked like a wild horse and the power dropped to a low acceleration. Once I backed off the throttle to about half-way the engine took off like "normal".
These symptoms were repeatable throughout my entire 500 mile trip. Is this a known issue with the EB?
Thoughts?
CMOS
Old Nov 23, 2016 | 07:03 PM
Liam_Harrow's Avatar
Liam_Harrow
How many miles? Did a CEL come on or blink? I would guess a misfire if you're on your original plugs. I had mine replaced at 45k with these same issues. https://www.ford-trucks.com/forums/1...-replaced.html
Old Nov 23, 2016 | 07:43 PM
CMOS's Avatar
CMOS
I'm at 72K original plugs (AFAIK).
There was never any CEL when the conditions were observed.
CMOS
Old Nov 23, 2016 | 07:46 PM
CMOS's Avatar
CMOS
Did you also change the COP's themselves? The coils? That would be rather expensive.
Please expand on the service. Replace plugs and - ?
CMOS
Old Nov 23, 2016 | 09:26 PM
Liam_Harrow
The service that I had performed replaced the plugs and boots with motorcraft plugs gapped to .030. I had it done at ford for 450. It fixed the problem for me. When I had it done they also cleaned the fuel system and did a software update.
72k is a lot on original eco plugs.
Old Nov 24, 2016 | 06:45 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Mine lasted for 61K miles and then I experienced the exact same symptoms. Romped on it, it misfired, CEL flashed for a few seconds, I let off the gas and it took right off. As long as I wasn't demanding a ton of power it was running perfectly. Once I nailed, it acted like it was going to shut down. Replaced plugs and boots and problem solved.
Be wary though, the original diagnosis on mine was a random misfire but when I got the service report back, it showed as the #2 plug was the main culprit. 7000 miles later and I experienced the same exact misfire again, CEL flashing, etc. I took it back tot he dealer and the #2 COP was failing. So, that was a portion of the original problem. I negotiated the dealership's failure to properly diagnose the issue and got them to reduce the bill significantly for COP change. They verified the COP failure by swapping out COP's from other cylinders.
This isn't a horrible issue and it's an easy repair. The EB are inherently tough on plugs.
Old Nov 24, 2016 | 08:13 AM
CMOS's Avatar
CMOS
OK.
1. What plugs for my 2012 EB? Do you by chance have a part number?
2. I'm going to replace the plugs-only first, then check the performance.
CMOS
Old Nov 24, 2016 | 09:13 AM
Liam_Harrow
These are the motorcraft plugs
https://www.amazon.com/gp/aw/d/B009B...R227PB1P44DN2J
Here are the boots if you wanted to do those too
https://www.amazon.com/gp/aw/d/B008B...BN3GS349DAAK8Z
This is also very helpful
Old Nov 24, 2016 | 09:19 AM
CMOS's Avatar
CMOS
https://m.youtube.com/watch?v=A042BqRDHTc
Great. I just ordered the 6 plugs and all new boots.
CMOS
Old Nov 26, 2016 | 07:33 AM
Mr. Mcbeevee's Avatar
Mr. Mcbeevee
Originally Posted by CMOS
Howdy All,
Thoughts?
CMOS
My eco-boost had the exact same symptoms At around 52,000 miles. CEL light never came on. $60 worth of plugs, some anti-seize lube, and an hour and a half in the basement had it running as good as new again.
Old Nov 26, 2016 | 09:57 AM
CMOS's Avatar
CMOS
Nice. I should receive my parts later this afternoon, and will do the install after church tomorrow.
Can anyone give me a technical explanation of what causes this issue? Is the problem the plugs themselves, or the boot dielectric breaking down causing a spark short to the head???
CMOS
Old Nov 27, 2016 | 12:25 PM
CMOS's Avatar
CMOS
Update: back to full power.
I changed all the plugs and all the boots. The "old" plugs were consistent in their appearance but did have a large gap, all were at least .040.
Thanks for all the help.
CMOS
Old Nov 27, 2016 | 01:38 PM
Liam_Harrow
Great to hear!
sprint car
2004 - 2008 F150
Aug 28, 2012 08:47 PM
Mmaxed
Modular V10 (6.8l)
17
Nov 17, 2011 12:41 PM
stevez69
24
Jul 6, 2010 08:37 PM
trooper180
Modular V8 (4.6L, 5.4L)
31
Aug 23, 2007 05:50 AM
caprichos4
Aug 11, 2004 03:49 AM
