Need distributor advice 89 5.8
Old Nov 16, 2016 | 12:27 PM
Pheadrus's Avatar
Pheadrus
I bought a 1989 F250 4x4 ex-cab/long box with a 5.8/C6 to replace my 89 7.3idi/zf5 plow truck. It has a remanufactured 5.8 with less than 20K miles on it. I got it for a great price at $250 US but the owner said it will sometimes stall in the Summer when hot and not want to start until it cools down again. I drove it home with no issues. I'm assuming the TFI module is likely the culprit.
To get it running and bypass other possible issues in the dizzy(PIP), what new drop in dizzy is recommended? I know members have complained about aftermarket dizzy's being problematic. I'm up in Canada so a MSD type unit costs me about $600 CAD after exchange, taxes, etc. And I've heard members say these units can have issues as well. The local NAPA quoted me around $230 CAD but I read those are junk as well.
I do have a 95 F150 parts truck with the roller 5.8 and remote mounted TFI setup I plan to put on the 89 but Winter is almost here and I wanted to try and get it running before the snow flies. How easy is it to modify the 95 TFI wiring harness to work on the 89? Is it better to just swap the 95 dizzy into the 89 so I don't have to make a block off plate for the 89 dizzy? My current plow truck is running fine but I had the typical IDI oil pan rust issues that caused a small hole in the side of the oilpan. I had a buddy use a gas tank repair patch on the pan but I'm worried it may start to leak during the Winter and I'll be screwed.
Old Nov 16, 2016 | 05:26 PM
Conanski's Avatar
Conanski
Yeah that is one of the classic TFI failure modes.
You can't bypass the PIP.. just put a new grey TFI module on the dizzy and forget about it. None of the aftermarket parts are recommended because they are much less reliable than OEM and there are absolutely no gains to be had with any of them. A new Ford TFI module should last the life of the vehicle.. given your seasonal use.
Old Nov 16, 2016 | 06:25 PM
Pheadrus's Avatar
Pheadrus
Thanks Conanski. What I meant by bypass is just put a whole new dizzy instead of changing the TFI and finding out the PIP is bad, or shaft play, etc. What is the part number for the Motorcraft TFI? Any suggestions for a source for them?
Thanks.
Old Nov 17, 2016 | 09:21 AM
Pheadrus's Avatar
Pheadrus
Anyone have the part number for the Motorcraft TFI and where I can buy one?
Thanks.
Old Nov 17, 2016 | 09:45 AM
rla2005's Avatar
rla2005
Thanks.
Motorcraft - DY1074 (supercedes DY425)
Ford - 5U2J-12A297-AA, 5U2Z-12A297-A
Any good parts store will carry or can order one for you. If you can wait, try RockAuto. A site sponsor.
Old Nov 17, 2016 | 10:38 AM
Pheadrus's Avatar
Pheadrus
Thanks. But I've heard from a buddy who is a mechanic that Rockauto has substandard parts. That they buy blems and 2nd stock. He said to stay away from electrical parts especially. Is this just B.S? I bought a pair of brand name "professional" grade drums and one was badly out of round and I had to get it machined. A buddy bought shocks from RA and the welds on them were hideous.
I'm in a smaller community in northern Canada and the only parts store is NAPA. They said they only have "Ackland" brand TFI's which they say is made by Standard.
Old Nov 17, 2016 | 10:45 AM
Pheadrus's Avatar
Pheadrus
Rockauto doesn't seem to list them anymore. Just brands like Standard, Delphi, etc.
Old Nov 17, 2016 | 10:55 AM
Pheadrus's Avatar
Pheadrus
I found some DY-1074's on Amazon and Ebay for around $160US. What about this one? Or are these the ones Ford recalled? E43Z-12A297-A
MOTORCRAFT IGNITION MODULE FORD CAR TRUCK VAN LINCOLN MERCURY MERKUR | eBay
Old Nov 17, 2016 | 12:40 PM
rla2005's Avatar
rla2005
I've never had an issue with electrical parts from RockAuto. If I ordered off-brand items, I got what I paid for. Sorry to see they are not carrying Motorcraft brand ICMs.
I do not think I would use the earlier version part number parts. There is a reason why they were upgraded. Searching on the Ford part number yields some positive hits on Amazon and other places stating they are truly Ford parts.
one_bolt_short
13
Jun 6, 2017 11:52 AM
geoasis
20
Mar 26, 2015 02:46 PM
cpg
28
Jan 25, 2014 12:23 PM
Mudman
Oct 11, 2010 07:11 PM
BRay09
31
Sep 1, 2009 11:00 AM
