I Have a 1969 F100 Short bed RWD 360 originally with a 3 on the tree, a previous owner converted it to a 4 on the floor. I bought a rebuilt Borg Warner T-85 3 on the tree with R-11 over drive but it didn't come with the linkages from the lower column down to the transmission. I am hoping someone on here has a set I could buy or know the dimensions/schematics or know someone or somewhere that I could find them, I believe I could use the linkages from a pickup from the '50s all the way up to 1972.
Ford type 3.03 3 speed manual & T-85N 3 speed manual with overdrive use the same shift rods, but 1967/71: There are THREE different types of low & reverse & 2nd & 3rd shift rods.
Did you also get the T-85's O/D cable, wiring harness, kickdown switch and relay?
