Sponsored by: Auxito
'02 4.6 Rebuild Question
Old Jul 30, 2016 | 11:03 AM
bass-n-fire's Avatar
bass-n-fire
I'm rebuilding the motor in my daughters truck. It's an '02 Lariat Supercrew with 4.6. I had to have the crank turned due to Rod bearings seized. My question is do I need to replace the bolts for the main bearings or are they reusable?
Old Jul 30, 2016 | 01:16 PM
bass-n-fire
After doing some research, I need to replace the main bearing cap bolts, rod bolts. Where can I get these?
Old Jul 31, 2016 | 09:32 AM
70f100longbed's Avatar
70f100longbed
Make sure you get the rods checked at a good machine shop. When the bearing spins it distorts the rod. You should be able to get the bolts from your favorite parts store. Replace the head bolts too.
Old Aug 2, 2016 | 10:35 PM
bass-n-fire
Thanks for the input.
Old Aug 3, 2016 | 08:03 PM
bass-n-fire
Ok, so far, I have that only the dealerships and Summit Racing have the bolts for the main caps and rod caps. Problem is, Summit is showing multiple kits. Some with bolts, some with studs. Mine has 9 bolts and 1 stud.
fljab
Mar 30, 2015 06:28 PM
rayinsd
2004 - 2008 F150
May 24, 2012 11:49 AM
JACKA$$
Jan 29, 2010 09:19 AM
bigblockford_390
Dec 22, 2007 11:34 PM
AC-MAN
Modular V8 (4.6L, 5.4L)
Oct 26, 2005 11:52 PM
