AIR BAGS WITH LIFT, 2006 NAVIGATOR
Old Jul 22, 2016 | 02:27 PM
mikemrq's Avatar
mikemrq
Is there a lift kit that I can lift my 2006 Lincoln Navigator 2 1/2" and still keep my air bag system? Everyone says you need to use coil over with the lift spacers. Is it possible to put a coil over in the front with lift spacers and keep the back air bags with lift spacers? I would like to at least keep the air bags in the rear in case I put a heavy load in the back, it will level out.
Old Jul 29, 2016 | 05:19 PM
mikemrq's Avatar
mikemrq
anyone that can answer this please
Old Aug 11, 2016 | 03:00 AM
QuadManiac's Avatar
QuadManiac
How much lift do you want?
Old Aug 11, 2016 | 06:04 AM
mikemrq's Avatar
mikemrq
About 3". Can I put a 3" lift on the front and rear then make 3" longer sensor arms? Was looking to get this kit. Let me know what you think.
http://www.ebay.com/itm/371655159762
Old Aug 11, 2016 | 08:43 PM
5.4T's Avatar
5.4T
Post a picture of your truck so I can see the height,I might be able to help but first u will need a measuring tape, flat head, 13 mm rachet and for the rear height sensor 12 or 11? Can't remember the size...but basically your going to trick your hight sensors and best part you don't need to cut or drill anything!
Old Aug 11, 2016 | 08:47 PM
mikemrq's Avatar
mikemrq
can you explain in more detail. It's just a stock 06 Lincoln Navigator. No cutting or drilling? After installing the lift, I don't need to make longer sensor rods?
Old Aug 11, 2016 | 11:26 PM
rowekmr's Avatar
rowekmr
I am surprised that no one has made a module that allows owners to adjust the height of their Navigator yet. Since it is all computer controlled is seems that it will just take some programming. I like you would like to raise mines for my personal taste.
awkoop
Nov 19, 2009 03:15 AM
lovestrucks
Nov 9, 2009 10:55 PM
GForces
Apr 30, 2008 11:14 PM
semperfipsd
May 22, 2005 09:54 PM
