Radiator For 50 F-1
Radiator For 50 F-1
I put a 352 big block in my 50 F-1. I'm having a hard time finding a radiator that has the right size inlet and outlet. I need a 1 3/4" inlet and 2" outlet. Every one that will bolt up to the stock mount are 1 1/2" inlet and 1 3/4" outlet. Does anyone know someplace that sells what I need? I'd like to go with an aluminum one.
Gary,
Check out U. S. Radiator, here:
Ford - Radiators
These are their Ford truck radiators. If they don't list what you need here. Find one of their dealers near you and go talk to them.
Philip
Ford - Radiators
Philip
You can also use radiator hose reducer bushings. You can get them at NAPA;
Napa carries rubber hose reducer bushings. Here are the P/N's;
NBH-900 from hose 1.5 to 1.25
NBH-901 from hose 1.75 to 1.5
NBH-902 from hose 2.0 to 1.75
NBH-903 from hose 2.25 to 2.0
NBH-904 from hose 2.5 to 2.25
NBH-905 from hose 3.0 to 2.5
Gates also makes them. If you can find a decent parts guy behind a counter they might be able to locate them.
I also used a mid 70's Dodge big block truck radiator in my 49. I'm running a 500ci Caddy.
Bobby
Bobby
aussiecowboy
09-10-2012 07:00 PM
49fordF-1
10-23-2011 10:32 PM
67falconer
02-08-2009 01:39 PM
