oil change on hpop
Old Jan 25, 2016 | 03:43 PM
onebadv2's Avatar
onebadv2
oil change on hpop
ok, I'm stuck inside due to some recent shoulder surgery and have been watching anything an everything on YouTube about 7.3's or diesels in general. I've been on this forum many times but have never ran across anything that discussed what the Powerstrokehelp guy had to say about injector care. States the oil in the hpop or top end of the motor does not circulate as in other areas of the engine. Therefore, he says the oil needs to be sucked out of the hpop and replaced. recommends doing this in 3 increments at a quart removed and replaced each time with 5 minutes run time between. Any thoughts?
Old Jan 25, 2016 | 03:54 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Ignore anyone that insists you need to change the HPOP oil. The oil in that reservoir comes directly from the oil pan and cycles fairly quick. NOTHING good comes from sucking out the HPOP oil but many bad things can (and have) happened. It's not worth messing with so just stick to the regular oil change intervals and you should be fine. I change my oil every 8-10k miles.
Old Jan 25, 2016 | 04:18 PM
Absolute's Avatar
Absolute
I think what he must have meant was that in order to do a complete oil change you have to drain the HPOP reservoir as well since it holds a volume of oil. He couldn't of meant it didn't circulate, cause how did it get there then?? He meant it doesn't drain back to the pan, but it does circulate.
Old Jan 25, 2016 | 04:24 PM
Shake-N-Bake
It's possible that is what he meant but even so.....changing the HPOP oil still won't result in a complete oil change. There is oil in the reservoir/front cover that can't be accessed with a suction tube so no matter what.....all the oil can't be evacuated. Then there is about a quart of oil in each cylinder head.
It's really a waste of time to suck out what little of the HPOP oil that you can get with a suction tube. It's like tossing a hand full of sand on a camp fire in hopes it will extinguish the flame. The risk/reward ratio is prohibitive so it's best to leave the HPOP alone when performing an oil change.
Old Jan 25, 2016 | 06:32 PM
z31freakify's Avatar
z31freakify
I did this often on the fleet, kept the oil clean even at 4k but after a while it started to get old and i just stoped doing all together. On my obs I do it once every 3 oil changes to keep the oil nice and clean
Old Jan 25, 2016 | 06:35 PM
Bonanza35's Avatar
Bonanza35
Don't waste your time. If you have bad injectors some guys suck it out and put in there type of snake oil to help them out. All oil goes back into the pan at some point. This oil changes fairly quickly and bends back in with the rest. Like said above there is much more oil in other places that don't get changed out either.
Old Jan 25, 2016 | 06:55 PM
CampSpringsJohn's Avatar
CampSpringsJohn
This is why that guy has no credibility on here! He claims to have built many 7.3's, and, maybe he has. My question to him would be, where does the oil go once it flows to the injectors? Back to the HPOP? NO! It goes to the oil pan!
Like every one else said, not necessary to change it. Now, if you have a way to suck out the pint or so, then feel free to do it. But his reasoning is so far off reality it ain't funny.
Old Jan 25, 2016 | 07:27 PM
binuya's Avatar
binuya
Besides being unnecessary, a big downside is possibly damaging that HPOP reservoir plug. That plug isn't meant to be removed and replaced regularly and if you mess it up, you're in for way more work than you set out to do. Plus, you increase the chances of dropping foreign material into it.
Old Jan 25, 2016 | 07:31 PM
Absolute's Avatar
Absolute
I think the original poster did not write what actually was said. Or the guy in the video explained it terribly, as I did above. What I think he is saying is. If you want to do a COMPLETE oil change you have to change the oil in the pan, hpop reservoir, and rails. To do this you drain the reservoir (Pan empty), fill reservoir with new oil, crank 5 times to pump it into rails and push old oil out into empty pan so dirty oil is not pumped into engine killing the plan. Then repeat 2 more times to get new oil all the way threw. So the Only failure in his explanation is you only drain the reservoir once, and just fill it 3 times, and the pan must be empty. So the theory is solid, just a waste of time if you ask me. In fact, the best way to change the tranny fluid is with a very similar procedure.
Old Jan 25, 2016 | 07:34 PM
CampSpringsJohn
I for one ain't gonna hit the key with no oil in the crankcase to test his idea.
Old Jan 25, 2016 | 08:02 PM
Absolute's Avatar
Absolute
Ya, if for some reason I wanted to even do this. I would crank by hand. Makes no difference, its gear driven, no need for speed.
Old Jan 25, 2016 | 08:16 PM
F350-6's Avatar
F350-6
If you have any doubt about how well oil circulates through your HPOP reservoir, remove the plug on the top of the reservoir and crank the engine.
You might have some clean up to do, but all doubts will be removed about weather enough oil flows through the reservoir to provide enough circulation.
Old Jan 25, 2016 | 09:07 PM
Pikachu's Avatar
Pikachu
No, he said it doesn't circulate. I saw the video where he said the high pressure system a closed system. I think the guy is a complete tool.
Old Jan 25, 2016 | 09:11 PM
Absolute's Avatar
Absolute
Hahaha. That's funny. I never saw the video and forgot he said it doesn't circulate. Post the link , I want to see.
Old Jan 25, 2016 | 09:52 PM
Shake-N-Bake
I presume you would unplug the CPS to keep the engine from starting? Even so, it still won't drain all the oil. Cranking (or turning by hand) 5 times will only pump HPOP oil through the IPR and then to the pan. The oil rails in the heads will retain the used oil. Only way to evacuate the 2 quarts in the heads is to remove the oil rail plugs or pull the injectors.
