Losing the lift
Old Jan 10, 2016 | 10:59 AM
timmytoes's Avatar
timmytoes
Losing the lift
I have a 6" lift with 37" tires and I'm wanting to go back down. My thought is dropping to a 2" lift and maybe 33s. If I'm correct, that lowers it 6" because I only lose half the hieght of the tires. Is that assumption correct?
My other question is can I reuse the U bolts in the rear or is that not recommended?
Thanks!
Old Jan 10, 2016 | 11:06 AM
jswartz84's Avatar
jswartz84
The u bolts for the rear would probably be pretty long, but you could always cut them down.
I think factory the truck came with 33's. A leveling kit clears 35's.
Old Jan 10, 2016 | 11:13 AM
Jmoen7's Avatar
Jmoen7
Thanks!
Go down to stock rear and 2" level upfront and you'll fit 33's fine
Old Jan 10, 2016 | 02:22 PM
timmytoes's Avatar
timmytoes
Thanks fellas. I started wondering about that after I posted the original question. When I originally had it lifted, I had to put traction bars to help with the axle wrap. Guess I won't be needing those any more.
Old Jan 10, 2016 | 02:38 PM
WatsonR's Avatar
WatsonR
why not.. they will help with axle wrap without a lift as well.
Old Jan 10, 2016 | 08:44 PM
timmytoes's Avatar
timmytoes
I don't recall having any prior to lifting it. Who knows? Maybe I'll keep them onI wish I would've left the lift alone now. Sure did look good though. Guess I just grew out of it. That and I don't need the ground clearance any more. Pretty much a pavement princess except for the occasional gravel road with a six pack. i guess they look kinda cool though.
Old Jan 11, 2016 | 03:54 AM
WatsonR's Avatar
WatsonR
35" tires and a 2" level in the front still looks great. Bed is low enough to be useful and doesn't require two men to get heavy stuff into the back.
can you see yourself getting into the truck at 65.. carrying a step stool isn't an option!
Old Jan 11, 2016 | 12:39 PM
geniusloerts's Avatar
geniusloerts
Everything I have ever read says do not reuse u-bolts. They are cheap enough to err on the side of caution.
Old Jan 11, 2016 | 03:32 PM
timmytoes's Avatar
timmytoes
You're right there! The way I feel, I need a step stool now and I'm 46. Your comments make a lot of sense. I may go that route. It'll make it easier to work on too.
Old Jan 11, 2016 | 03:35 PM
timmytoes's Avatar
timmytoes
It seems as if I've heard that before but wasn't sure. Just curious as to why though, other than being too long or too short. I'm planning on replacing them but I got to wondering if it was a necessity or not.
Thanks
Old Jan 11, 2016 | 04:36 PM
geniusloerts
found this
Old Jan 11, 2016 | 04:44 PM
timmytoes's Avatar
timmytoes
Well, there we have it.
Thanks!
Gary86
2009 - 2014 F150
Sep 3, 2010 08:12 PM
ford4x4956
May 14, 2010 09:21 AM
PSDmike
2004 - 2008 F150
Sep 5, 2008 02:08 AM
goldman
17
Feb 5, 2006 09:58 PM
LariatAggie
2004 - 2008 F150
Feb 29, 2004 11:26 PM
