Motorcraft 10w 30
Old Dec 28, 2015 | 03:07 AM
derek0525's Avatar
derek0525
Motorcraft 10w 30
Went to get oil tonight at Walmart and I got some Motorcraft 10w30 it says Ford powerstroke on the label so I'm guessing it can be used in the 7.3 or is it for the newer trucks I was using Delo 5w40 but they were out and the Motorcraft 10w30 was only $17 for 1.25 gal jug.
Old Dec 28, 2015 | 07:58 AM
rufushusky's Avatar
rufushusky
The diesel rated (CJ-4) Motorcraft 10w30 can be use in a 7.3 PSD without issue.
Old Dec 28, 2015 | 01:45 PM
snknby123's Avatar
snknby123
Will you be towing? Apparently, there are limitations on the 10w-30 if towing above certain temps.
Here's some info:
https://www.ford-trucks.com/forums/1...aft-10w30.html
Old Dec 28, 2015 | 02:07 PM
rufushusky's Avatar
rufushusky
Here's some info:
Here is for the 7.3:
The chart in the thread referenced is for a 6.7 IIRC.
However, they only recommend a 5w40 for under 30*F which doesn't really make sense IMHO. I have towed in the summer with a 10w30 and plowed in the winter with it w/o issue. In the coming years 10w30 will start displacing 15w40 as the PC-11 oils come online.
Old Dec 28, 2015 | 03:49 PM
snknby123's Avatar
snknby123
Thanks for referencing the correct chart. rufushusky has it covered. It should be in your manual as well.
Old Dec 28, 2015 | 05:59 PM
derek0525's Avatar
derek0525
Don't have my manual but Ibguess it's ok to use then
Old Dec 28, 2015 | 09:18 PM
dn29626's Avatar
dn29626
10w30 diesel rated is the oil these trucks came from the factory with.
I ordered and continued using it for many miles before switching to 15w40.
dmags
6.7L Power Stroke Diesel
Jul 31, 2012 06:32 PM
dsblk93gt
39
Apr 3, 2008 02:11 AM
hi-jacker
Mar 22, 2007 10:29 PM
Vulcan3.0
Oil & Lubrication
Mar 15, 2006 07:22 AM
snort
Jan 14, 2006 03:13 AM
