Fuse Block Upgrade
Old Oct 21, 2015 | 01:59 AM
burnthelight88's Avatar
burnthelight88
Fuse Block Upgrade
Has anyone upgraded the fuse block alone? I know that a new full wiring kit will come with one, but my wiring is fine and its not in the budget to replace everything right now. I would love to upgrade the fuse block to blade or mini-blade fuses. It would also make it easier for me to add new circuits in the future. I've seen the idea mentioned in multiple threads, but have never seen anyone that did it. I tried a search with no luck. Anyone that can point me in the right direction?
I think that I could manage without any help, but if someone's done it I always prefer to read someone else's experience first.
Old Oct 21, 2015 | 05:02 AM
Jrgunn5150's Avatar
Jrgunn5150
I haven't done it, but I have been researching it and have come across quite a few people who simply used a junkyard block.
My 75, only has like five circuits lol. I think it would be as easy as wiring a block for power, then swapping each circuit over.
I have this page bookmarked,
http://www.rowand.net/Shop/Tech/GMATOStyleFuseBlock.htm
Old Oct 21, 2015 | 08:11 AM
lafermedavid's Avatar
lafermedavid
fuse block
I believe NBC Steve has done just that,look into his past threads
Old Oct 21, 2015 | 08:15 AM
Canus's Avatar
Canus
I added an auxiliary fuse box (think it was from a Focus) to power my electric fan, headlight relays, and allow for additional circuits (fog lights, stereo, etc.) Not that difficult a job and it takes a load off the original fuse box.
Old Oct 21, 2015 | 09:44 AM
4x4slik's Avatar
4x4slik
I did a partial on my 74 f100. When I got it, I was searching for some electrical problems. What I had found was that most of the wires had been cut at the fuse block. I added a 6 fuse block for bat power items, and left ign power items in original fuse block. You can buy small fuse blocks from most Auto parts stores. You basically have 2 circuits, and so you would need 2 blocks. You can get bigger ones with the capabilities of doing bat and ign power in one block, but they get into the hundred dollar range.
Old Oct 21, 2015 | 11:38 AM
akguy09's Avatar
akguy09
I added a 7circuit block from Painless Wiring to my 76'. It has 3 Ignition hots and 4 Constant Hot. I have switched some stuff over from the truck and I run my tach\radio and aux lights off of it.
Old Oct 21, 2015 | 12:09 PM
HIO Silver's Avatar
HIO Silver
Made my own using a DelCity.net fuse block and relays...
Old Oct 21, 2015 | 01:03 PM
burnthelight88
I actually have a hook for a two circuit fuse block, plus grounds, under $50 from when I used to outfit emergency vehicles so I was planning on using that.
HIO, great work as usual and now that you posted it I do remember seeing that in earlier pictures. What all do the relays control besides (I'm guessing) the hi/lo beams?
Old Oct 21, 2015 | 01:07 PM
HIO Silver's Avatar
HIO Silver
Thanks.
Driving lights, fog lights, inner and outer roof lights, rock lights... all are fed by the auxiliary battery.
Headlight relays are over by the main battery.
Old Oct 22, 2015 | 02:38 AM
burnthelight88
Turns out the fuse block I have a hook for will not have enough room. My current block has 8 ignition fuses and 2 hot fuses; the one I had a line one was limited to 5 ignition fuses and 6 hot fuses. Looks like it's time to fabricate.
Old Oct 22, 2015 | 09:48 AM
ZarK-eh's Avatar
ZarK-eh
I would simply add another fuse block to unload the original. This way you can save money for better upgrades.
You can see mine from a newer truck or ranger on the passenger side by the upgraded starter relay/solenoid (which I painted beige for some reason...) https://i.imgur.com/NorQDum.jpg
I'm sure you can find something that will work to off-load the existing wiring.
Old Oct 23, 2015 | 02:05 PM
Notmeofficer's Avatar
Notmeofficer
You bet you can ... Go to blue seas site.. They make marine electrical components. They have stand alone fuse blocks that are perfect for replacing our existing fuse blocks. Regular modern fuses... 8 and 12 sizes.... And relatively inexpensive... I give them four stars and use them in every truck I have.... Along with the Whalen 10 switch fused swithbox.... Makes wiring easy peasey
Old Oct 23, 2015 | 04:36 PM
burnthelight88
Yeah the one I had a line on is just like a roided out Blue Seas one, which I was also familiar with from doing some Google searches on the topic. I think I'm gonna push this project off until next year.
Old Oct 24, 2015 | 08:36 AM
78 PEB's Avatar
78 PEB
I just checked out the Blue Seas website, Cool stuff! Bookmarked for later use!
90pioneer
13
May 23, 2013 11:04 AM
Oscar Meier
Electrical Systems/Wiring
Sep 10, 2004 09:59 AM
Franklin2
Nov 12, 2001 02:38 PM
