It was running pretty good with an intermittent miss so I thought it needed plugs, wires and such.
Just put new plugs, plug wires, cap and rotary button. That is all I did. firing order is good. Is hard to crank, I have to pat the gas, and it will not idle.Sputters at low idle,
carb is fairly new. filter is open.
I don't think it is the coil as it does run.
Could the ignition control unit be bad causing this.
Make 100% sure the wires are in the correct place in the cap and at the plugs. Don't say they look good. Trace each wire. Make sure you have them in the cap with the proper distributor revolution.
IT just had an intermittent skip. Nothing real bad but not as smooth as a fine running motor. At speed it did fine. I can't even drive it now. It acts like it is not getting enough gas but I think it is. It will run at higher rpms
Well, I was wrong. I took it out on the hiway and it really, It is now fixed. It will not get up- to speed, It runs like it is starving for fuel.
Mind you, before I changed plugs and wires it was running pretty good, just not great.
I have checked each plug with a spark plug checker which is hooked to the spark plug and wire and lights up when it fires. They all are working.
One plug looks different than the others. It is brown and all the others are white. When I pull that plug wire while running, it does not seem to affect the way it is running. It is cylinder 4.
I am sure before that it was getting fuel and now, all of a sudden it seems that number 4 is not.
