1954 f100 retro questions
Old Oct 6, 2015 | 05:54 PM
lichtyr's Avatar
lichtyr
Guys I need some help , I am retro modding a 54 f100 with a 4.6 engine and trans from a 2006 markViii can anyone help me to understand what it would take to use the rear end out of this car and install it is a independent drive with axle shafts
Old Oct 7, 2015 | 08:02 AM
ETOWN55's Avatar
ETOWN55
Look on a facebook page called 53-56 F100 Crown Vic suspension swap. some people on that page have done the swap. They sell a kit to do the swap search it up. I don't remember the site that sells it.
Old Oct 7, 2015 | 08:15 AM
ETOWN55's Avatar
ETOWN55
What are you going to use for the front suspension.
Old Oct 7, 2015 | 10:27 AM
lichtyr's Avatar
lichtyr
I am not positive been looking at a 2004 crown vic , but also thinking about a mustang II what do you recommend
Old Oct 7, 2015 | 11:57 AM
ETOWN55's Avatar
ETOWN55
Either or will work depending on your budget. With the Crown vic IFS you would have to run a mustang type of wheel in front. A +offset like a 35mm and a 16 inch wheel or greater. A mustang II suspension the variety off wheels is a lot more options.
Old Oct 7, 2015 | 04:42 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Not sure what you've got Mark VIII's were produced from 1992 to 1998? They had 4.6 DOHC engines, a 4 Speed Automatic Over Drive (AOD) Transmission and a Independent Rear Suspension (IRS).
https://en.wikipedia.org/wiki/Lincoln_Mark_VIII
Pleanty of Folks have installed the IRS and 4.6 in all configurations 2V, 3V & 4V in their trucks. If you use a 03-11 Crown Vic Independent Front Suspension (IFS) the 4.6 engine will bolt into the Cradle. OBTW any Panther Platform Vehicle's cradle will work. The hard part is the electronics. But again, several have sucessfully accomplished thew install.
Last edited by bjmayberry2; Oct 7, 2015 at 04:43 PM. Reason: added Panther Platform
Kellyblues
Mar 15, 2016 06:22 PM
Glen66
1947 and Older Ford Trucks
Feb 8, 2015 06:54 PM
Alex159872
Apr 11, 2014 11:02 PM
jaye
Jul 17, 2006 02:27 PM
