Please help - 2002 Excursion New Falken Tires, I feel unsafe
Old Jul 13, 2015 | 10:49 PM
Hortuna's Avatar
Hortuna
Here's my deal. I just replaced my BFG 295/75/16 with Falken Wildpeak H/T 265/75/16. Immediately I noticed instability when driving on the freeway. "I was all over the road". But, it got much worse..... Two weeks later I towed my 26' toy hauler trailer with two seadoo's inside. About 8,000 lbs. total (my guess) I could not keep the truck and trailer in my lane at speeds over 60MPH. I fact when I applied the breaks, The truck would swerve into the next lane. needless to say I drove at 55 MPH with a pucker factor of 10.
Since, I've installed airbags with no help to the problem. My truck towed just fine before the change to Falken Tires..
Any ideas what's going on??
Please HELP.
Old Jul 13, 2015 | 10:56 PM
Big Sky's Avatar
Big Sky
Are the Falkens 10 ply?
Old Jul 13, 2015 | 10:57 PM
USCG_PA's Avatar
USCG_PA
I am really not a tire expert, but what are the new tire ratings? You should be running a load range E rated tire, if they are D's or less, then they will not be stiff enough to safely take the weight of the Ex and especially the weight of the tow. The squishy tires could also be the source of your wandering and stopping issues.
Also, out of curiosity, is there a reason you went with the smaller 265/75/16 tire? I mean, you lost about two inches in diameter...
Old Jul 13, 2015 | 11:11 PM
Hortuna's Avatar
Hortuna
8 ply, Load Range E.. 265 are the stock size and I'm doing everything to increase MPG.. Current MPG not towing is 13.2 @ 70 MPH..
It actually towed fine with the BFG 295/75/16 load range D..
Thanks again
Old Jul 13, 2015 | 11:28 PM
Apocalypse's Avatar
Apocalypse
I would take it back ASAP and demand the correct tire. Those are obviously unsafe and not right for the vehicle. Instead of trying to get an extra .0001 MPG get the right tire and guarantee that you won't kill anyone else on the road or yourself trying to save a buck.
Old Jul 13, 2015 | 11:29 PM
Apocalypse's Avatar
Apocalypse
Location? What year and motor are you driving?
Old Jul 13, 2015 | 11:32 PM
Hortuna's Avatar
Hortuna
Orange, CA. 2002 V10
Old Jul 13, 2015 | 11:50 PM
twigsV10's Avatar
twigsV10
Try rotating the tires front to back, I have had a bad new tire that had bad belting from the factory and would expand on one side of the tire at highway speeds and really mess up the alignment. Granted it was on a car but I have also experienced new tires that were nowhere near round on trucks.
Old Jul 14, 2015 | 04:01 AM
bcrewcaptain's Avatar
bcrewcaptain
How is this NOT the "correct" tire?
It's the size they rolled out the door with, and is rated to tow anything the truck is capable of.
There are a lot of factors that could however make them handle differently than the tires you took off. First step would be play with the tire pressure. Every truck is going to act differently, there are just too many factors to make a blanket statement as to what will fix the issue. It has 2 plys less than a lot of E rated tires, which also could lead to some extra sidewall flex. Even the tread pattern itself can lead to some extra movement that is unexpected. Play with the tire pressure first, make the place you got it from aware ASAP you are not happy, in case you do need to bring them back.
Trial and error here....a lot of people swear by Michelin tires and won't go with anything else, in my case, I hated them, and they cause my truck to handle and ride horribly, Kelly tires at were over $100 cheaper per tire were a HUGE improvement.
Old Jul 14, 2015 | 05:54 AM
carbon coupe's Avatar
carbon coupe
Generally, Falken tires are complete junk. I would shed them and get a set of Coopers or BFG's.....especially if you're towing. Safety is worth the extra dough.
Old Jul 14, 2015 | 06:40 AM
1 Excursion camper's Avatar
1 Excursion camper
It takes some time for the tires to "season". meaning they need to be run through a few heat cycles to stiffen the sidewalls. I know it sounds crazy, but it is explained very well just about anywhere.
Old Jul 14, 2015 | 07:13 AM
harley4jcs's Avatar
harley4jcs
WELCOME to the world of XXXs
Please add Orange CA to your profile Because it will be lost in this thread.
Did you get them at Discount Tire ?? If yes, take them back per there ride guarantee . I've never heard anything like the above post concerning heat cycles BUT if so, you would still have plenty of time (30 days) to get a tire that you like
Old Jul 14, 2015 | 07:48 AM
Bananarama's Avatar
Bananarama
I have always bought Michelin LTX MS2 load range E. I average 90,000 miles per set. I also inflate them to 80lbs and that helps with fuel economy and they always wear well. Those tires you got there.... they are an economy brand.... and they are worthless. source? 10yrs in the tire business. Thank god I'm out.
Old Jul 14, 2015 | 09:11 AM
WE3ZS's Avatar
WE3ZS
Hortuna, can you post a picture of the sidewall data from one of these new Falken tires? I'm asking because according to Falken's website they do not make a load range E 8 ply tire in that size. WILDPEAK H/T TIRE | Falken Tire. They do make a 10 ply load range E as well as a P metric tire in the same size. The P metrics would deliver the type of performance that you have described here, for a short time until they fail.
I had a set of Falken's on my old Chevy beater pickup, bought 2 new ones and put them on the rear and truck was all over the place. Swapped to the front they handle fine, once worn in an rotated back to the rear they were fine there, weird. I never towed anything heavy with that half ton truck.
What tire pressure did you used to run in the old tires? What pressure do you have in the new ones? What is the max pressure listed on the tire sidewall?
Old Jul 14, 2015 | 10:00 AM
Apocalypse's Avatar
Apocalypse
8 ply Just because it came from the factory with those doesn't make it correct.
