98 Expy 5.4 Head replacement. Parts list?
Old Jul 6, 2015 | 09:37 PM
Firefighter 1406's Avatar
Firefighter 1406
I am looking for a parts list that I will need to purchase to replace the head on my 98 5.4. Spark plug hole stripped, dealer fix didn't hold, stuck replacing head. Was wondering if anybody have a parts list.
Thank you
Old Jul 9, 2015 | 10:56 PM
Firefighter 1406
I have read a bunch on this but I haven't seen a parts list yet. Anybody?
Old Jul 10, 2015 | 01:43 AM
Skauber's Avatar
Skauber
It kind of depends if you're on a budget or not. Are you getting a re-manufactured head, or a junkyard used head?
Old Jul 10, 2015 | 04:39 PM
Firefighter 1406
I am am still up in the air on that one. Not sure how much one is at a junk yard yet, reman is $700. I am worried about all the work and then put a junk yard head on it. I am leaning reman probably. Is that going to mess up the engine with one older side and one new?
Old Jul 10, 2015 | 09:28 PM
Skauber's Avatar
Skauber
I don't think it will be much difference unless the other head is really worn out. Rockauto sells heads for $700 with a $125 core refund if you return the old one, maybe you can get a similar deal from the one who quoted you for a head already. Personally, if I was doing cylinder head, I'd replace the timing as well while I had the engine open. You will have to time the engine anyway, so slapping new sprockets, tensioners, chains and guides on to it would not any extra work, and I think you can get a timing set for about 200 bucks.
Other than that, it's gaskets for everything. Timing cover, head, valve cover, intake and exhaust. New head bolts of course, and studs for the exhaust manifold as the old ones will most certainly break.
Also, inspect the other head to make sure it's not showing signs of wear, as it would suck if you do all this and then the other head goes bad after a few months..
Old Jul 10, 2015 | 10:35 PM
Firefighter 1406
I appreciate you help. I was thinking the timing stuf as well. Truck has 198,000 on it. Debating on pulling the engine or trying to do it in the truck. Trying to get whatever special tools are required together. Everything I have wad says this is a pain in the butt so not really looking forward to doing it at all.
Old Jul 11, 2015 | 01:55 AM
Skauber's Avatar
Skauber
It is easier doing it with the engine out of the truck, you'll have much better access to everything. But it is also possible to do it while the engine is in the truck, depends if you have the necessary equipment available to pull the engine and mount it on a engine stand or not. If you don't have those, it's more practical to do it in the truck. If you do take it out, it opens up the possibilities to inspect other things as well, and remove and clean the oil pan and lower end of the engine. After almost 200k miles, there's most likely some gunk in there..
Old Jul 13, 2015 | 05:57 PM
Chris71Mach1's Avatar
Chris71Mach1
I'd say find a set of PI heads out of a junk yard and port them yourself. Youll probably need the PI intake manifold too though, but after that just the normal gaskets that would come with replacing the heads.
Old Jul 13, 2015 | 09:00 PM
Firefighter 1406
Has anybody used the Lisle 65900 or ATD 5400 to drill out and retread a head on the truck?
Old Jul 13, 2015 | 09:34 PM
Skauber's Avatar
Skauber
Don't forget new bolts. Most probably knows that, but for those who doesn't, never reuse head bolts, always get a new set of bolts whenever you take off a cylinder head.
Old Jul 13, 2015 | 09:37 PM
Skauber's Avatar
Skauber
Not familiar with those, but I know that most swear to the Time-Sert inserts
http://www.timesert.com/html/triton_repair2.html
Old Jul 14, 2015 | 08:57 PM
Christine Rigel's Avatar
Christine Rigel
Have a question have a 99 expy V8 with a 5.4 took it apart and was replacing the head gaskets there was a balley cover or heat shield that was all broke up is it a necessary part to go back in not sure how much good it was doing anyway beings it was so broke up????
Old Jul 14, 2015 | 10:10 PM
Skauber's Avatar
Skauber
Do you have a picture?
Old Jul 15, 2015 | 10:00 AM
alloro's Avatar
alloro
Some cylinder head bolts are designed for 5 uses.
Old Jul 15, 2015 | 10:42 AM
Skauber's Avatar
Skauber
I guess it depends on the design, but I'm under the impression that most heads are designed with TTY head bolts, and reusing TTY bolts is a very risky thing as they will be weakened when being torqued to yield a second time and are more likely to fail. Saving a few bucks on bolts when doing a cylinder head replacement isn't really worth it...
As it pertains to the 5.4, my Ford Factory shop manual for the 2005 says the cylinder head bolts are torque-to-yield and cannot be reused and must be discarded along with the head gasket upon removal.
A quick search on the topic: https://www.google.com/search?q=reus...%20bolts&rct=j
