Head installation 4.0 91 ranger ohv
202,000 miles 4.0 ranger ohv
1. GASKET ASSEMBLY:
After head gaskets and heads are torqued to 44lbs book says to put the silicone that comes with the kit on the four corners where the heads and lower intake manifold meet, put the intake manifold gasket on and again put the silicone on. How far do you spread it up the head or between the heads?
The gasket kit said all the way between the heads and didn't mention putting it on under and over the gasket.
2..HOW TO CLEAN: (what to soak them in? or?)
The inside of the exhaust manifolds
The inside of the upper Intake manifold
The inside of the lower intake manifold
The inside of the fuel manifold
2. EXHAUST MANIFOLDS: Can I use anti seize compound on the exhaust manifold to heads bolts.
They only get torqued to 19 lbs so concerned they might rattle loose with the compound, but they were so rusted when I took them off one broke.
The Felpro gasket set comes with exh manifold gaskets and when I took the manifolds off they had not gaskets. Do you use the gaskets?
Should I replace those bolts, I need at least 2. Can I just get any bolts the same size and thread?
Can I use anti seize compond on the exhaust manifold to exhaust bolts.
Should I replace those?
Any other tips for assembly are appreciated.
The intake should require silicone in the corners where the head/block/manifold meet. When it's time to put on the valve covers on, you need some more silicone at the seam where the intake meets the head. The intake gasket for my '98 Explorer also required silicone on the front and back of the intake/block joint.
I used gaskets made by Fel Pro. I don't know what you have. There are two different sets/designs from Fel Pro. The instructions are different based on design.
For the intake (upper and lower) on my Aerostar, I had the machine shop clean. On my Honda, I just used carb cleaner. It's a trade of money vs. time.
Fuel manifold? Do you mean fuel rail? I didn't do anything for the fuel rail. It should be protected by the filter.
