Engine ID number on block, anybody know what this is ?
Old Jul 27, 2003 | 11:37 AM
bryan78f1504x4351mc6A's Avatar
the number on the back of the block, is 9U146935. the numbers on the tag on the valve cover are 5.8w'D'(C2XR124) Engine Displacement 5.8l 351 CID trans.auto. problem is, i dont know if the valve cover is the original one on engine, so need to be sure the engine is actually a 351 windsor
Old Jul 27, 2003 | 01:04 PM
searched forums, decided to get number off the intake, it is
D9DE 9425 CB, found out that the first D means 70's the 9 makes it a 1979 the D is supposed to be what kind of car it was in, but unable to determine what kind a car D stands for, any ideas ?
Old Jul 28, 2003 | 09:13 AM
Henry_the_Ford's Avatar
Henry_the_Ford
You will have a number on the block that is similar to the one on the intake it will give you more info on the motor so you can compare years....i'm not sure where it is on the 351 but on the 302 its above the starter.
Old Jul 28, 2003 | 04:23 PM
TheWiz427's Avatar
TheWiz427
Henry_the_Ford is right get the casting code off the block it's in the same area as the 302.
Old Jul 28, 2003 | 10:18 PM
Henry_the_Ford
http://www.dennis-carpenter.com/pdf/73-79_trucks.pdf
this site page 6 tells the full meaning of Casting numbers....if you order the catalog (free) it will give you a quick reference page for casting numbers and the door plate numbers.
the D you were having trouble with could be the following:
Falcon 60-69
Maverick 70-74
Granada 75-82
LTD 83 and up
Old Jul 29, 2003 | 11:18 PM
thank you, very helpfull information
Old Aug 5, 2003 | 09:49 PM
Bikeitswift's Avatar
Bikeitswift
You have to remove the starter to read that number (yet another "better idea"), its not as bad as having to pull the intake then the heads to read the head casting numbers!
351FordVanE250
Sep 25, 2020 09:52 AM
joehd8811
Nov 11, 2016 11:56 AM
jemini
Sep 3, 2016 05:49 AM
cartmanea
Mar 26, 2011 06:26 PM
Beanscoot
May 21, 2007 11:14 AM
