'86 Ranger Ammeter & Temperature Gauges Inop
Old Oct 7, 2014 | 07:55 PM
1939geezer's Avatar
1939geezer
My ammeter & coolant temperature gauges have quit responding. Does anyone have "easy" ways to check these circuits before I disassemble the dash? And, if the gauges DO turn out to be bad, where can I get replacements?
Thanks
Geezer
Old Oct 7, 2014 | 10:53 PM
Old93junk's Avatar
Old93junk
I would say you lost ground to part of the dash, any other things stop working?
Old Oct 8, 2014 | 01:27 AM
87 XLT's Avatar
87 XLT
Yep, could be a ground problem. Check that the strap from engine to firewall is there.
Old Oct 8, 2014 | 07:15 AM
tomw's Avatar
tomw
If the fuel gauge still works, you voltage 'limiter' is still functional. There are two connectors that plug into the back of the flexible circuit that works the gauges & lights. They can come loose, or get 'schmutz' on them that may affect the signal coming in.
I would check the temp gauge by turning the key to ON, and grounding the sending unit wire. If you have a 2.3, it is on the drivers side, below the intake manifold, above the oil filter. If you ground it, the gauge will move to full tilt quickly if it is connected. The ammeter is a different animal, and depends on Voltage difference between the battery and the load to imitate an ammeter. It is not a real ammeter. I just know it is very simple and if it doesn't work, and it is not a gauge problem, it is wire splices or corrosion type damage between the output of the alternator and the load/battery junction. At the 'junction' the alternator output can go to the battery if charging is needed, or power the load. If it goes from the battery, one side of the ammeter is lowered relative to the other and the gauge moves. Probably the poorest explain...
tom
Old Oct 8, 2014 | 02:37 PM
KF4EYR's Avatar
KF4EYR
on my 89 ranger i had gauges go goofy,,it turned out there is a circuit board under the headlight switch inside dash that went bad,, replaced it all started to work again......
AerostarDad
32
Jan 20, 2017 01:39 PM
three on the tree
45
Oct 14, 2016 10:27 AM
briana compton
1997 - 2003 F150
Aug 28, 2011 08:32 PM
sandyc
6.7L Power Stroke Diesel
Feb 23, 2011 11:26 PM
eigenvector
Feb 17, 2004 10:32 PM
