new drive shafts
So, for 6", I'd say yes according to the shop I talked to.
Kevin K.
I got hooked up with this shop through my cousin. The shop wants to put pix of his off-road truck in their ads, so he gets some good deals. I haven't really looked anywhere else.
Kevin K.
You will probably need to have both shafts reworked. I just went through this on my 77'. I had a longer slip yoke added to the stock rear shaft which actually required it to be shortend by 1/4". I also had 1330 u-joints (1310 is stock) added which, with the cost of the new yokes ($50 apeice), offset the savings of having the old shaft reworked vs. getting all new. The rear shaft would have bolted up but the slip yoke would have pulled apart when the suspension dropped. Your situation will depend on whether you have a long bed or short bed. My truck is a short bed so I had less room to play with.
The front shaft will need lenghtened for sure. Mine was 1/4"-1/2" shy of bolting up. Even if it did bolt up it would have been in bind at ride height. A Double Cardan joint needs to be added to avoid binding. When you go with a DC joint you also need to change the corresponding yoke. U-joint and DC yokes are different. Reworking your stock front shaft really won't save you anything since there is only about $1.00 of tube involved. My front shaft with 1330 joints and DC joint ran me $475 including the new 1330 yokes. The rear shaft ran me $225 to have it reworked. All that includes new u-joints and balancing. I had my shafts done at Six States Distributors of which there are a few throuhout the Northwest. Each shops prices will vary but that should give you a ballpark figure of what you're looking at.
