2008 F250 leafsprings fit on an 05 Ex?
Old Mar 27, 2014 | 03:55 PM
FordFamily6's Avatar
FordFamily6
Have a quick question, read about spring upgrade in the tech folder for the Ex and found some leafsprings on the innerweb that are off a 2008 F250. Are those a good option for upgrade over stock 05ers in an Ex? Im looking to solve the handling issue as well as level things out. I'm good with an increase in height.
Also, how do you find spring code? Is it on label in door jamb? I can't find where i read that.
Thanks!
Old Mar 27, 2014 | 04:04 PM
Kdr358's Avatar
Kdr358
They will not fit, the 08+ are longer and slightly wider. If its 4x4 you will have other issues since Ex's never had coil spring 4x4.
Old Mar 27, 2014 | 06:45 PM
X-Hibition's Avatar
X-Hibition
I think there is an adapter hanger kit to mount the newer leaf springs in the older (ours) vehicles. Someone should chime in...
Old Mar 27, 2014 | 06:57 PM
Forest's Avatar
Forest
There is actually a way to do this, so I've been told. But...it involves moving the front spring perch forward by 8" to accommodate the longer asymmetric springs. PDombrowicki has done this. I think the rear hanger location can remain unchanged.
But...more than the front spring perch must change, IIRC. The 2008 axles are different and thus probably have a different mounting block for clamping to the spring(?). I don't know--never tried it.
Old Mar 27, 2014 | 07:28 PM
Kdr358's Avatar
Kdr358
The 08+ springs actually are weaker than the 99-07 years. Ford tired to soften the ride by adding softer springs and larger rear blocks.
I had the factory G code rear springs with 300,000 miles on them when I hauled home 20 50lb play sand bags at just over 1000lbs. The EX fit it all nice and snug with minimal sag in the rear, maybe 2.5 inches of overall sag.
I took a 700lb skid home with my bumpers yesterday with my 14 F250 and from 700lbs it squatted closer to 3 inches.
IMO swapping the 08+ springs will do the same as the factory G code springs.
Old Mar 27, 2014 | 07:49 PM
FordFamily6
Oooooh I missed that the newer trucks had front coils. I'll keep my leaf spring search within the appropriate years! Thanks for the info.
Old Mar 27, 2014 | 09:09 PM
timf150's Avatar
timf150
Here is what someone went through to get the 08 springs on his F250.
https://www.ford-trucks.com/forums/9...onversion.html
Tim M
grumpyinme.
19
Apr 16, 2018 12:22 PM
the_webers_inc
Jun 26, 2005 10:51 AM
Karellen
Oct 26, 2004 10:28 PM
muddyford75
Oct 17, 2004 02:14 PM
