Metal Finish Question
Old Mar 2, 2014 | 06:08 PM
fabieber's Avatar
fabieber
I removed all the paint and rust from Floyd's valve covers getting them ready to powder coat.
The wire brush on the drill left the covers with a really cool shiny/etchy aluminum looking finish which looks really good on the engine.
What, if anything, can be done to keep that look and prevent them from rusting?
Old Mar 2, 2014 | 06:43 PM
1oldtimer's Avatar
1oldtimer
Engine paint clear coat. I used it on my cal customs and old edelbrock intake, it dulled them a little.
Before Clear coat, straight out of the blast cabinet (fine glass beads):
After spray can engine clear coat:
Old Mar 2, 2014 | 07:11 PM
Rimrock F1's Avatar
Rimrock F1
I used Eastwood's Diamond clear on my 56 intake. Still looks the same 2 years and 6000 miles later. Friend who painted it for me said the only problem he had was he could not tell what he had already sprayed. I can't tell there is anything on the intake. Thermostat housing was not sprayed and was old when installed so that's why the difference in color
Old Mar 2, 2014 | 07:46 PM
fabieber's Avatar
fabieber
Thanks Oldtimer and Mike. I hadn't thought about clear coat which I assume would act just like paint as it relates to sealing the surface from rust.
Old Mar 3, 2014 | 10:21 AM
AXracer's Avatar
AXracer
If you want to powder coat, use clear powdercoat, or use silver powdercoat and steel wool after. There are a lot of interesting powdercoat finishes.
These people have 6500 colors including many textural finishes: http://www.prismaticpowders.com/powder-coating-colors/
Old Mar 3, 2014 | 10:30 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The guys with flatheads with fancy finned aluminum heads use this stuff: Nyalic®
If it can take the heat of a cylinder head, it will do well on a valve cover.
Old Mar 3, 2014 | 10:58 AM
CharlieLed's Avatar
CharlieLed
Hey Ross, have you any experience with this Nyalic? This is a new product to me so I did some research on it...they caution against using any chemicals around it including degreasers. Most of the stuff I look for, such as Glisten PC, is very durable.
To the OP, you may want to check out GLISTEN PC, might be overkil but it works great on any metal including rock chips on wheels.
Old Mar 3, 2014 | 02:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Not sure which product you saw that on, Charlie. I don't have personal experience but Mike Bishop and other trustworthy sources use it. I don't have a lot of shiny on my engine!
From Nyalic's auto page:
"Nyalic is effective for environments exposed to acids, salts,urea, fly ash, mag chloride, lime, water, snow, ice, and sea air.
"Solvent-based chemicals can damage
Nyalic-coated surfaces. Avoid using
solvent-based cleaning solutions.
Damaged surfaces can be repaired with
Nyalic aerosol can."
Not clear if solvent-based cleaners includes Gunk-type cleaners with kerosene? I could believe something more aggressive would damage just about any coating. But from what I've heard, strong solvents/cleaners aren't needed on Nyalic-coated parts, they just wipe clean.
Old Mar 3, 2014 | 04:44 PM
CharlieLed's Avatar
CharlieLed
Yeah Ross, I read that but I also took a look at the MSDS sheet as well. If Mike Bishop uses it and is happy with how it performs than I would imagine that it would be good enough for my ole truck! If it wasn't so pricey I would pick some up and give it a little real world testing with some gasoline, oil, Gunk, SuperClean, brake fluid, and who knows what else. Always better to know what's gonna bite ya and then steer clear of it.
Old Mar 3, 2014 | 08:57 PM
carnut122's Avatar
carnut122
I would recommend clear engine paint over powder coat. Don't ask.
Old Mar 3, 2014 | 10:53 PM
fabieber's Avatar
fabieber
Does don't ask mean it didn't go well? I was about to choose powder coating as it seems like the consensus product.
Old Mar 3, 2014 | 10:54 PM
fabieber's Avatar
fabieber
Thank you for this info. If I use this I will report on the outcome
Old Mar 3, 2014 | 11:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1
On the other hand, I bet none of Mike's engines leak a drop of anything...
It is not recommended where gas will be dripping on it. (Intake manifolds) I understand Eastwood used to sell it (or still does) under their name.
Old Mar 4, 2014 | 05:04 AM
carnut122's Avatar
carnut122
Apparently, the aluminum expands and contracts at enough of a rate different than the powder coat to cause cracking (or maybe it was my "do-it-yourself" application? However, I've not had it happen on any of my other powder coating projects). Then, my Summit Racing powder coating hasn't played well with the heat rising from the headers (I figured if you can have plastic intakes, the heat can't be too bad....wrong). I suspect there's a high temp version of coating; go with it if you decide to go this route.
Old Mar 4, 2014 | 10:51 PM
fabieber's Avatar
fabieber
I spoke to the folks at POR15 today. While they endorse the Glisten PC clear coat for the valve covers they were adamant that it will not prevent rust on the now stripped metal. But, neither will their engine enamels - you just won't be able to see the rust with a color. They do have a clear rust preventive product but said it will turn amber.
So, they recommend using their rust preventive base coat then engine enamel over that. Bummer - the covers really look good with the brushed metal finish.
