Offy C series carb mounting
Old Jun 25, 2003 | 06:48 PM
65GreyGhost's Avatar
65GreyGhost
those of you that are using the c series intake and 2 bbl or 4 bbl carb which way are you mounting the carb? i see there is a devider under the carb that goes part way down the runners. also any clues on what u use to hook up the throttle and choke cables?
Old Jun 25, 2003 | 07:05 PM
gdavis2265's Avatar
gdavis2265
Check my gallery for a (poor) pic on the way I mounted my carb. I made a spacer out of 1" plate (used Cad and a burn table) used a piece of heavy wire (from a small steel tomato plant trellis, of all things) and cut the stock ball and socket linkage in half- welded both ends to rod - my linkage runs lengthwise to truck- has forked great for the past year.
