Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Power steering in 750 and larger?
Old Nov 16, 2013 | 07:48 AM
GJCAT's Avatar
GJCAT
The N series I just bought has manual steering. How common is powersteering on the bigger F,N,C,&L trucks? I`d like to put power on this beast. I had a L600 that was nonpower and it was a beast to turn in tight places.
Old Nov 23, 2013 | 12:12 AM
dmanlyr's Avatar
dmanlyr
Well I can tell you that the T950 that I recently purchased came standard with power steering so I have to assume the parts are out there to convert yours. The C600 that I also have also has power steering.
So parts should be readily available.
I probably should add that most of the larger truck models also had optional what was called a center point steering axle, these did not have power steering as the steering geometry was designed such that the steering was easier than with the standard steering setup.
David
jailbird 88
Oct 18, 2002 12:17 PM
Motoryder714
1983 - 2012 Ranger & B-Series
Dec 21, 2001 12:13 PM
