Rear Seal Change
Old Oct 4, 2013 | 05:40 PM
50th ann's Avatar
50th ann
Rear Seal Change
How hard is it to replace the rear seal on my 2010 F-150 Automatic.
I have a small leak at 88,000 Miles.
Old Oct 6, 2013 | 10:34 AM
stuart1's Avatar
stuart1
Lift vehicle.
Use supports.
Clean area around the extension housing.
Mark drive shaft in relation to differential.
Remove drive shaft. ( some fluid will dribble )
Remove seal.
Clean seal area.
Apply sealant to the exterior metal surface of the new seal.
Apply grease to the rubber seal area.
Tap it in.
Check ujoints.
Clean yoke.
Replace drive shaft.
Remove supports.
Lower vehicle.
Old Oct 6, 2013 | 02:40 PM
50th ann's Avatar
50th ann
Rear Seal
Thanks - I appreciate the help.
Will the seal pop out if I carefully pry it out with a screw driver. Moving from one side of the seal and then the other side?
Old Oct 6, 2013 | 03:13 PM
85e150's Avatar
85e150
Note the design here, and just watch yourself with the screwdriver or other tool so you don't ruin anything.
Lisle 56650 Adjustable Seal Puller
Old Oct 6, 2013 | 03:58 PM
50th ann's Avatar
50th ann
Great idea - Well worth the twelve dollars - Thank You
Old Oct 6, 2013 | 04:04 PM
stuart1's Avatar
stuart1
Just use a screwdriver tapping side side.
With a hammer.
bradleydm
May 28, 2011 11:33 PM
upinthenorth
1997 - 2003 F150
Sep 8, 2007 07:19 AM
Halibut4
Sep 9, 2006 02:08 PM
RobbyMartin
1997 - 2003 F150
Mar 14, 2006 06:41 PM
cmlind
Apr 27, 2005 07:31 AM
