97 PSD cel comes on and loss of power
Old Jul 14, 2013 | 07:16 PM
hayesmsr's Avatar
hayesmsr
I'm having a tough time with my 97 4x4 5 speed. Once I put my foot into it in 5th the cel comes on and it turns into a dog. If I shut it off and restart it it runs fine till I do the same thing. When the cel comes on the icp won't go over 2471 and the ipr is 34.9 wot. Changed the oil 1k miles back and just replaced icp thinking I had found the problem. No problems starting and there is no rough idle. This is my first diesel so speak slow and use small words. Thanks
Old Jul 14, 2013 | 08:17 PM
427 fordman's Avatar
427 fordman
Do you have a chip? How many miles are on it? Have you checked for the code? It sounds like your high pressure oil pump is weak.
Welcome to fte.
Old Jul 14, 2013 | 08:30 PM
hayesmsr's Avatar
hayesmsr
No chip. 317000. Unable to clear the codes to start fresh
Old Jul 14, 2013 | 08:31 PM
hayesmsr's Avatar
hayesmsr
Is there any way for me to check the hpop?
Old Jul 14, 2013 | 10:51 PM
ReBilld's Avatar
ReBilld
Not sure, but a clogged map tube could maybe cause this. Take it off and blow through it to see if it's clear.
Old Jul 15, 2013 | 05:31 AM
427 fordman
The code it set would tell us. I'm guessing its a 1211 code with the numbers you put up.
Old Jul 15, 2013 | 06:09 AM
hayesmsr's Avatar
hayesmsr
New wrinkle this morning. It took longer for the cel come on. After it did I pulled over and shut it off then restarted it. It would not start. Icp was showing 323 while cranking. I pulled thee icp plug and it coughed and sputtered but did start. Icp was showing 727 at idle same as when the cel is on. Dont know if this helps or makes it more complicated. The map tube is clear.
Old Jul 15, 2013 | 12:22 PM
427 fordman
I'd like to hear other opinions, but I think you have a sticking ipr going off this last statement. The code is stored in the computer if you haven't removed the battery cables.
Old Jul 15, 2013 | 12:58 PM
hayesmsr's Avatar
hayesmsr
P0001, 0004, 0006, 0007, 0076, 0110, 0111, 0173, 1900, 2873, 3426, 3920
I am unable to clear the codes so I don't know what's old or current. Even removed battery cables for over an hour and was still getting the same codes
Old Jul 15, 2013 | 05:38 PM
427 fordman
What are you using to pull the codes?
Old Jul 15, 2013 | 06:27 PM
hayesmsr's Avatar
hayesmsr
Scangauge2
Does it sound like this could be uvch?
Old Jul 15, 2013 | 06:49 PM
427 fordman
Those codes don't make a lot of sense to me. That scanner can't be reading right, some of those don't exist on the powerstroke.
Have you visually inspected the harness on the outside of the vc's?
I'm thinking ipr because I think you should have been higher than 34% dc at wot. Then when you unplugged the icp it "unstuck" it somewhat and fired, but has been randomly sticking on you. You can pull it and disassemble it and clean it, if it is your problem it sometimes seems to work to clean them. If you pull it you will need orings to put it back in.
Anyone else have an opinion?
Old Jul 15, 2013 | 07:20 PM
hayesmsr's Avatar
hayesmsr
The ipr does go higher just not when the cel is on. It seems like the cel comes on when I really get into the throttle for more than a few seconds. Didnt look at the uvch but have seen lots of threads on it. Was just wondering if it could cause these symptoms
Old Jul 15, 2013 | 07:51 PM
fordpride's Avatar
fordpride
UVCH won't do that.
Those codes aren't right.
With the ICP unplugged you won't be able to see the ICP reading. Ehat you are seeing with it unplugged is the PCM taking a wild azz gues
With out having the true code it's a crap shop.
The issue is ipr or hpop
Old Jul 15, 2013 | 08:15 PM
427 fordman
Thanks Mike.
