Gas pedal repair
Old Jun 28, 2013 | 08:19 AM
sammatt1's Avatar
sammatt1
Gas pedal repair
Has anybody successfully did a swap on the gas pedal? Tried to remove the rod/pin holding the plastic rectangular piece but will not budge. Soaked it with some PB blaster and tried hammering it out but will not move at all. I can't use any heat since it will probably destroy the plastic piece.
The hardest part I think is trying to remove the rod/pin on the Excursion since it can't be hammered out without destroying the whole gas pedal assembly.
Any ideas on how I can accomplish this swap? I just can't do a simple gas pedal assembly swap since my Ex has the adjustable pedal. The F250 is a regular one.
Been driving the Ex with a broken gas pedal for 2 years now and its time to get it fixed. Not certain how the previous owner managed to break this pedal.
Old Jun 28, 2013 | 11:34 PM
Sader's Avatar
Sader
Looking at the splines on the pin I would say it is a tall order to remove that pin! That looks to be a high interference fit from experience. Have you tried using a hydraulic press?
Old Jun 28, 2013 | 11:49 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Grind each bolt flush using dremel. Redrill new hole on X post. Use a similar size bolt to attach
Old Jun 28, 2013 | 11:54 PM
tims01's Avatar
tims01
jb weld and fix the old one ..or take your ex to a dealer and get the recall done for a new footpedal if yours qualifys
Old Jun 29, 2013 | 07:16 AM
sammatt1's Avatar
sammatt1
Thanks for the input guys.
Sound like the best option is to cut the pin and replace it with a bolt. Thx Tylus.
After doing some research, the recall only applied to '02-'03 trucks, mine is an '04 -- was only good til March '04.
hello113
May 18, 2019 12:08 AM
MAULMAUL
Nov 21, 2012 06:09 AM
soooop
Aug 16, 2010 09:17 AM
4x4bigblock
Feb 23, 2006 06:05 PM
icantdo55
Apr 3, 2003 07:20 AM
