Would like pic of assembled front brake caliper... 2003 2WD
Old Apr 28, 2013 | 11:39 AM
Jeckler's Avatar
Jeckler
I have terrible short term memory. Maybe I have terrible long term memory too, as I can't train myself to do one side at a time on brakes.
Anyway, I've replaced the rotors, calipers and pads on the front of my 2003 2wd Expy and I may have goofed installing the outside spring, the one that clips into the caliper, not the zero drag spring on the inside pad. I'm not sure if it's supposed to ride on the caliper mount, or the tabs get pushed "out" (away from the hub "out") to keep the pad up against the caliper mount and the abutment shims as they're called in the hardware kit. As it is now, they're on the mount, and the outside pad wants to push away and ride on the outside. I just want to make sure. I haven't driven the truck yet, except around the block, where I have a terribly spongy pedal.
Does someone have a pic they can post of how this spring sits on their ride? Even a pic through the wheel of the top and bottom of the outside pad would probably work. Every pic I've found online so far just shows an exploded view.
Old Apr 28, 2013 | 11:49 AM
alloro's Avatar
alloro
Here is a PDF of the shop manual pages for the front brake. Hopefully you can see what you need to somewhere in the images.
File Type: pdf
Old Apr 28, 2013 | 01:10 PM
Hamfisted's Avatar
Hamfisted
Here's one from mine. Hopefully you can see what you need to see without me taking the wheel off .
-Mike
Old Apr 28, 2013 | 01:31 PM
Jeckler's Avatar
Jeckler
You both are awesome, thanks!
I had the anchor spring assembled wrong, and didn't even know that one end had two tabs. After refit and test drive, I have a pedal again and the outer pad is staying in place. The way I had it was forcing the caliper away from the hub instead of pulling it towards it. I think the last owner had it wrong too, as I was able to pull the caliper out without removing that spring first.
I'm attaching a pic of what the final result is.
Alloro, would you mind posting the procedure for the rear, please?
Imageshack won't let me rotate it, but this is the driver's side...
Old Apr 28, 2013 | 08:16 PM
alloro's Avatar
alloro
What...for free?
I've attached the rear brake pad and the rear parking brake shoe procedures.
File Type: pdf
File Type: pdf
Old Jun 9, 2013 | 02:36 PM
bigcrunch's Avatar
bigcrunch
Anyone have a good pic of how the zero-drag spring is installed in the front calipers?
Glad I was referredto this post, it helped!
Old Jun 9, 2013 | 03:33 PM
Jeckler's Avatar
Jeckler
IIRC, the short end goes into the clip attached to the inner pad and the long end into an indentation of the caliper. It really won't fit the other way either, as the coil of the spring will get hung up on the caliper.
POPAJON
16
Jul 30, 2023 03:13 PM
Filko
Jan 22, 2014 08:49 PM
460 FORD MAN
May 5, 2013 12:32 PM
Mudd460
Jun 18, 2009 05:01 AM
Jaaaaaaackman
Sep 24, 2006 09:28 PM
