Rear door won't open
Old Feb 15, 2013 | 11:21 PM
Kevin 1988's Avatar
Kevin 1988
I just bought my first ford a1999 expedition an the rear door won't open I can get the glass to open but not the door I would appreciate any advice thanks
Old Feb 16, 2013 | 11:31 AM
alloro's Avatar
alloro
There is a cable that runs from the release mechanism to the latch. Sometimes this cable breaks.
Old Feb 17, 2013 | 04:31 PM
Gevans17's Avatar
Gevans17
Expy rear liftgate wont open? - here ya go!
Kevin,
Alloro is correct. You have a non-operable cable release. Or more likely, a dry rotted rubber cable sheath. The wire cable itself is probably still intact, just not functional without the rubber sheath. The rubber sheath fits into a slot on the latch release mechanism.
this is the part number you need:
Ford Genuine F2UZ15264A65B Control Rod Assy Cable
You should know that Ford is very proud of this part, as it will set you back $50 each at the dealer. Found mine for $39 on E-Bay. Rear hatch release and the cable to release the rear window are the same part number. Both of my cables crapped out within 1 week of each other, so check both while you are in there.
You will need to remove the plastic trim around the window and then the rear door cover to access them. I was able to reuse the broken door release cable (without the rubber end sheath) by tieing the wire cable itself directly to the lock release with a couple of plastic cable ties. I used my new cable to replace the window latch release.
Old Feb 17, 2013 | 06:22 PM
johnkn's Avatar
johnkn
Is the lift gate frozen?
Old Feb 17, 2013 | 08:32 PM
Kevin 1988's Avatar
Kevin 1988
If I unlock it an turn it to the right the window open an when I turn it to the left it locks it an it seems to get the panel off I need the thing open
Old Feb 17, 2013 | 10:15 PM
alloro's Avatar
alloro
The panel will come off with the rear hatch closed. It helps if you can get the 3rd row seat out of the way to give yourself some extra working room.
Old Feb 17, 2013 | 10:58 PM
johnkn's Avatar
johnkn
You didn't answer my question, is it below freezing?
Old Feb 18, 2013 | 12:18 AM
Kevin 1988's Avatar
Kevin 1988
No I live in south Louisiana
Old Feb 18, 2013 | 12:32 AM
Kevin 1988's Avatar
Kevin 1988
There wasn't a third row in it when I bought it I played around with it today an still don't see a way to remove it with out breaking it
Old Feb 18, 2013 | 06:44 AM
Gevans17's Avatar
Gevans17
When you get that hatch fixed, i have a 3rd row seat i'm trying to give away if you want it. I live in south LA too.
Old Feb 18, 2013 | 06:47 AM
Gevans17's Avatar
Gevans17
rear hatch panel removal info
Trim Panel —Liftgate
Removal
  1. Remove the upper liftgate trim panel.
  1. Remove the liftgate assist strap.
    1. Remove the screws.
  1. Remove the lower liftgate trim panel.
    1. Remove the pushpins.
    1. Remove the trim panel.
Old Feb 18, 2013 | 07:22 AM
BAD RONALD's Avatar
BAD RONALD
Maybe this help you.
Old Feb 18, 2013 | 08:23 AM
Kevin 1988's Avatar
Kevin 1988
That would be great are you close to new orleans
Old Feb 18, 2013 | 08:25 AM
Kevin 1988's Avatar
Kevin 1988
This will help I was worried about breaking the panel but I'm gonna give it a try after work
Old Feb 18, 2013 | 10:08 AM
BAD RONALD's Avatar
BAD RONALD
... I was worried about breaking the panel ...
Remember that cold plastic breaks more reliably than warm plastic. I would run the rear heat for a while, park the truck in direct sunshine, wait for hot weather, etc. before removing trim and push pins. You will still break a couple of pins but save the panel.
