302 to 351m
I am new here and this is my first tread.
What I would like to know is any advice (tech. or opinions) about a 302/351m swap. I have an 83' bronco with a perfectly good 302 and an 81' bronco with a perfectly good 351m and good c6 tranny. the one in the 83' needs new trorc converter. I believe the 351m w/ trans will swap just fine, but not sure... by the way, you might wounder what is wrong with the 81', well i just bought it on ebay for $160 w/ brand new 31-10.50-r51's and runs but body and frame is rusted to pieces.
Also carb an 83' is newly rebuilt 2bl. will it swap from 302 to 351m.
Again I believe it will but not sure(I think they are the same carbs)
It shoud'nt be much trouble. Since the 81-86 broncos did'nt change much through the years, everything should be straight forward. I don't know if the motor mounts are the same between the 302 and 351m though. Sounds like a nice swap. Good luck.
