New member question from the dark side
Old May 21, 2003 | 08:50 PM
Lonnieramey's Avatar
Lonnieramey
OK, I'll admit I drive a Dodge Cummins, but please don't hold that against me. My Dad just bought a 95 Powerstroke.
He has a little problem. When he starts up cold the engine lopes a little and if you give it throttle its worse with white smoke. It will go away after you drive it for a little bit. I told him I thought it is a glow plug issue but don't know for sure as I don't have much experience with these things.
Any thoughts?
Thanks,
Lonnie
Old May 22, 2003 | 12:21 AM
The Diesel Dude's Avatar
The Diesel Dude
This is a fairly common problem. It is just another problem that Ford never got around to fixing. If it only does it at start up (cold), and it goes away when it warms up, it is probably a slow acting, sticking or lazy IPR valve. You might try to use a lighter oil in the crankcase. If you are using 10W40 or 15W40 try 10W30 instead (if you can find in diesel grade).
Old May 26, 2003 | 06:58 PM
Lonnieramey
Thanks Joe, I'll pass the info on to my Dad.
Old May 27, 2003 | 12:32 AM
JoeBoost's Avatar
JoeBoost
My truck does this when i start it in the cold chicago winters , but soon after it gets started , it will find it's idle and run fine...
