Hello I'm new here have stock wheel question
There are two different types of wheels, two different types of hubcaps. F100's have 5 lug wheels on a 5.50" bolt circle.
1) "Innie" wheel, so called because the hubcap (9 1/2" O/A diameter) snaps onto table located on the inside of the wheels center section. Last year for these wheels was 1966.
2) "Outie" wheel, so called because the hubcap (10 1/4" O/A diameter) snaps over tabs located on the outside of the wheels center section. Introduced in 1965, similar wheels used thru 1996.
There are two types of innie and outie hubcaps: Stainless steel (Custom Cab/Ranger) and painted (Standard Cab). The innie stainless hubcap has been reproduced.
Consider joining FTE's AZ Chapter. Bill W is the chapter leader, lives in Tucson, has several of these trucks. Garbz2 (Dave) lives in Glendale, both may have extra wheels.
My sister lives in McCormick Ranch, her house is the only one on the entire street with pine trees in the yard. No desert landscaping, nary a cactus.
I am a bit north of you almost to carefree highway.
DVAP has what you need but are kind of pricey.
Has any one changed out te diff to get a little more speed on the highway whats a good ratio my truck is bone stock except the ugly aftermarket wheels on it. I would upload a picture if I knew how.
When doing a resto, it's a good idea to have every repro parts sellers catalogs. All sell to each other and to the general public alike, so the prices for the same parts will vary.
15" x 5 1/2" innie wheels will be found on all 1954/66 F100's. The innie wheels used prior to 1954 are only 4 1/2" wide.
Outie wheels are faaar more plentiful since variations in width were used thru 1996, but the 1965/66 outie stainless steel hubcaps (C4AZ-1130-A - same as 1964 Galaxie) are not reproduced.
The AXLE code is stamped on the Warranty Plate, located on the left door face below the latch. Post what it is.
Whiz up from Northern from McCormick Parkway, see if you can spot the house with pine trees. It's on the east...lake side.
Here ya go. Now ya know how. We love pic's
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
The Henry 36 is available new and will accept the ford innie cap 15 through 17" and has a 5 on 5.5 lug pattern. Stockton is under new ownership and back in biz!
Stock wheels will not clear disc brake upgrades on 65s.
Garbz
[/IMG]
