1965 inner fender apron
Old Sep 14, 2012 | 07:27 PM
65 f100's Avatar
65 f100
Hi I have a 65 f100 2wd and I need a passenger side inner fender went on lmc and NPD all they have listed is 61 to 64 no 65s. Is a 64 the same or are they different if so does anyone make one or do i have fix my old one thanks for any info
Old Sep 14, 2012 | 09:47 PM
rusbukt's Avatar
rusbukt
Try the auction site. There are inner fenders on there all the time. Not cheap. A pair on there now for 250.00
Old Sep 14, 2012 | 09:55 PM
schoo's Avatar
schoo
i think that they are different had a 65' donor and inter fender but i'm on the west coast
maybe you could find a good donor
Old Sep 15, 2012 | 12:23 PM
daveengelson's Avatar
daveengelson
First and foremost, Welcome to FTE!! Don't hesitate asking questions, there is an abundance of knowledgable and helpful members. Looking forward to your input and post pic's when and if you can!! Again welcome!
Suggest check with a couple welding shops, and autobody shops, ask if the inner fender can be repaired; if so, how much, then decide whether to repair or replace. Not too often have I seen inner fenders on auction, if it appears seller is parting out his/her 61-66 Ford truck suggest email and inquire. With ebay one can search for particular items, recieve daily emails when simular/same items are place on auction, and also narrow search close to home. Purchased a hood this way, seller lived with 40 miles.
Fortunately, know couple buddys who are/have restored their classic vehicles and seen where a good auto body person can work miracles. I needed an inner fender repaired and got quotes from both weld and autobody shop and fiqured since it's an inner fender I would go with the welding shop because they were alot cheaper.
I have 2 65's and each had a different style inner fender. The 65 Std. cab the inner fender had more of a curve to them; whereas, with the 65 CC the inner fenders have more of an angle to them. Suspect has more to do with the month of production than whether or not it's a std or custom cab?
Old Sep 15, 2012 | 12:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I have a 65 F100 2WD and I need a passenger side inner fender apron. Went on LMC and NPD all they have listed is 61 to 64, no 65s.
Is 64 the same (No!) or are they different?
C5TZ-16054-B Right & C5TZ-16055-D Left .. Inner Fender Aprons / Obsolete
Applications: 1965/66 F100/250 2WD / 1966 F100 4WD
No Ford Dealer or obsolete parts vendor has the right side. / Green Sales has 2 left sides.
1965/66 Custom or Standard Cabs have nothing to do with inner fender aprons. These trucks are over 40 years old, so who knows if the original parts are present?
1965 F100/250 4WD, 1965/66 F350/700, 1966 F250 4WD use different aprons.
1965/66 F100/250 2WD's, 1966 F100 4WD's have coil spring front suspension, use the same cabs and Styleside beds.
All other 1965/66 F100/350's have a cab step, front leaf springs and if Stylesides, use the 1957/60 "wrong beds" so called because the bed lines don't match the cab lines.
abe
Mar 13, 2016 12:20 AM
glassmanbruce
Jan 9, 2016 09:30 AM
tomsixtyfour
Jun 14, 2005 11:45 PM
