Sponsored by: Auxito
Flat Towing a '99 F150??
Old Aug 11, 2012 | 05:39 AM
Supercab's Avatar
Supercab
Wink Flat Towing a '99 F150??
Can I flat tow a '99 F150 5.4 with automatic trans about 10 miles w/o removing the driveshaft? (flat towing is just towing with a chain or strap) Thanks!
Old Aug 11, 2012 | 06:27 AM
Archion's Avatar
Archion
Veteran: Marine Corps
2 or 4wd, if 4wd, auto or manual transfer case? And as far as legality, I know that in most states these days, towing with a chain or strap is highly illegal. They are only for pulling you short distances, like out of a ditch.
EDIT: Here are the recommendations from your Owners Manual.
2WD (manual and automatic transmissions)
1. Place transmission in N (Neutral).
2. Maximum speed is 56 km/h (35 mph).
3. Maximum distance is 80 km (50 miles).
If a distance of 80 km (50 miles) or a speed of 56 km/h (35 mph) must
be exceeded, you must disconnect the rear driveshaft. With the rear
driveshaft disconnected, the maximum speed is 88 km/h (55 mph) and
there are no mileage restrictions.
See your dealer for help with disconnecting the driveshaft.
4WD – Lever operated transfer case
1. Place transmission in P (Park) (automatic transmission), or R
(Reverse) (manual transmission). Engage the parking brake.
2. Shift the transfer case to N (Neutral).
3. Lockout the center disconnect by capping off one of the front axle
vacuum motor lines. See your Ford dealer for assistance.
4. Vehicle speed should not exceed 88 km/h (55 mph) and there are no
4WD – Electronic shift transfer case
2. Shift the transfer case to 2H (2WD high).
vacuum motor lines. See your dealer for assistance.
4. Maximum speed is 56 km/h (35 mph).
5. Maximum distance is 80 km (50 miles).
Old Aug 11, 2012 | 08:22 AM
Supercab's Avatar
Supercab
Thanks Matt, Our truck is 2wheel drive automatic trans-I think we can tow it 10 miles at 35mph or under to get it home-I hadn't heard that flat towing was illegal-I see folks doing it on interstates with a strap or chain though never know really if they get ticketed...
RickS1986
1997 - 2003 F150
Sep 14, 2018 08:24 PM
2011FX2Crazy
2009 - 2014 F150
Dec 21, 2011 10:49 AM
jbirdsvt
Feb 21, 2005 10:03 AM
fireball69
1997 - 2003 F150
Mar 10, 2004 02:28 PM
dkm
1997 - 2003 F150
May 29, 2003 10:16 PM
