02 Ranger, 3.0 flex, No Power on Acceleration.
Issue started with a misfire on 5 and rough running engine with no codes showing up. Now the motor is getting worse.
Idle a little rough and no power when accelerating hard. The engine sounds like a popcorn popper under hard acceleration. Motor revs up to 4K but does not pull or shift gears until I let off the gas.
The code that initially showed up indicated a bad Camshaft Position Sensor. Changed that and the Sync assembly - as per instrucions, exactly positioned same as old one. New codes showed up - P1152, P0175, P0171. Cleaned the MAF, rail fuel pressure OK, can't find any vacuum leaks, replaced both upstream ox sensors, and changed #5 ,6 injectors.
Motor still runs the same - like crap, like a corn popper on acceleration, smooths out if only slightly accelerating, but stumbles n bumps on steady cruise speed over/around 60 mph - and no codes showing at present.
I really, really don't want, nor can I afford, to take it to the dealership, but I may be forced to if I can't figure this out sometime quite soon. I make my living with this truck so, no truck, no work till this issue is solved.
The other codes are a bit confusing, as they seem to conflict with each other, unless you really do have two seperate problems, or maybe wrote down a wrong code number.
P0171 = Lean bank-1
P0175 = Rich bank-2.
P1152 = lack of bank-2 O2 sensor switching, indicating rich.
So if the bank one P0171 code is correct, here is a link with a list of things to check for.
P0171 - Check Engine Light Diagnostic Trouble Code Description
Some thoughts for consideration. Keep us posted on your trouble shoot.
Bank-2 running rich suggests the computer is having to add fuel because of too much air, maybe from an unmetered vacuum leak, or maybe an acting out/leaking/uncontrolable fuel injector has the bank-2 O2 sensor switching stuck Rich!!!! So doing a read on All cyl bank-2 spark plugs, might offer up a clue as to whats going on with bank-2.
Have you done a compression test yet, or hooked up a vacuum gauge to see what clues it suggests????
Did the problem come about suddenly, after some event, or slowly over time????
With the mileage on this puppy & not knowing its maintenance/repair history, or where you are on all due past & present scheduled maintanance replacement items, (other than the O2 sensor replacements & MAF sensor cleaning), it could be a number of things, so we need more clues to make better guesses on which way to proceed on your trouble shoot.
Has the PCV valve ever been replaced????
Bank-2 running rich suggests the computer is having to add fuel because of too much air, maybe from an unmetered vacuum leak, or maybe an acting out/leaking/uncontrolable fuel injector has the bank-2 O2 sensor switching stuck Rich!!!! So doing a read on All cyl bank-2 spark plugs, might offer up a clue as to whats going on with bank-2. sprayed stuff all over the engine with the motor running looking for vacuum leaks - no changes,
Have you done a compression test yet, or hooked up a vacuum gauge to see what clues it suggests???? compression test on all cyls. checked out ok. Valves'seats done >50K miles ago.
Did the problem come about suddenly, after some event, or slowly over time???? progressively showed up after changing the camshaft position sensor and synchronizer. Trans rebuilt >10K miles ago.
With the mileage on this puppy & not knowing its maintenance/repair history, or where you are on all due past & present scheduled maintanance replacement items, pm's done pretty much on schedule. (other than the O2 sensor replacements & MAF sensor cleaning), it could be a number of things, so we need more clues to make better guesses on which way to proceed on your trouble shoot.
The plugs are new - have they been checked since they were installed? How do they look compared to the plugs on the other bank?
Since the condition started to progressively show up after changing the camshaft position sensor and synchronizer, I think, if it were me, I would have a look at that - you mentioned that you "Changed that and the Sync assembly - as per instrucions, exactly positioned same as old one." - could it be possible you were sold a defective part or one that isn't quite working the way it should? How did the wiring and connectors look?
Good that you've kept the scheduled maintenance up & checked the PCV valve & that it's loose, not gummed up & sticking, BUT the PCV valve shake/rattle test isn't good enough, as if this puppy has never been changed in 375+K miles, its already lived nearly 3 life times, so there is no way to gauge how much internal wear has taken place, how well its seating/sealing, nor how weak its spring has become. SO, seeing as how its a calibrated for/unmetered vacuum leak, best to keep it replaced on time & thats usually around every 100K miles!!!! Carefully check its rubber fittings & hose for loose fit, dryrot cracks, ect.
I know you said the plugs were replaced, so how did the old ones from cyl bank-2 look for carbon fouling, or how do the new plugs look????
The computer is unhappy with fuel trim on both banks, one bank is lean, the other rich. O2 sensors give the computer feedback on the O2 level in the exhaust & the computer uses that info, along with other sensor inputs, to vary the fuel injectors squirt time, so that the air/fuel ratio in both cyl banks is kept as close to 14.7/1 as possible. So if we have unmetered air leaks, leaking fuel injectors, dirty, or clogged up fuel injector filters yielding a lean squirt, or corrupt feedback from the O2 sensors, fuel trim & the fuel trim tables stored in KAM get corrupted, so have you disconnected the battery B- cable, to wipe the KAM???? Then have you done the cold & warm idle relearn proceedure, so the computer can relearn its cold & warm idle strategy & begin to rebuild new fuel trim tables with the cleaned MAF sensor & new O2 sensors input????
Since we only have 2 O2 sensors, one for each bank of cylinders, we are seeing the average of all cylinders in a bank, so if one cyl is acting out, it'll corrupt the O2 sensor PID back to the computer for the entire cyl bank. Now if we had an O2 sensor for each cyl, it would be easier to know how each cyl is doing, but we don't have that luxury, so we have to revert to a spark plug read, to get an idea whats going on with a particular cyl air/fuel ratio.
Seeing as how you say compression is ok I assume you don't have any oil fouled plugs.....right?????
On the low power issue seeming to be associated with the replacement of the cam sensor & sync, I agree with Furyus1, have another look at that part & its alignment. Have a look at timing with an induction timing light at various rpm.
