Deluxe heater vs. Economy
Old May 9, 2003 | 08:25 AM
RobK's Avatar
RobK
Is there a different heater box used in the deluxe heater setup, or is "deluxe" just the added bracket and cables below the dash, plus the different temp valve and the "pull for defrost" trim ring under the fan switch?
Old May 14, 2003 | 06:19 AM
William's Avatar
William
Most that I have seen are as you described and this holds true for standard cab and custom cab trucks. The years would be 61-66 and maybe others.
