Low speed rear oscillation that gets better..
Old Jun 15, 2012 | 11:25 PM
compaddict's Avatar
compaddict
That goes up in frequency and still noticable but goes down in amplitude at highway speed...
It feels like a loose rear wheel between 10-15MPH and at freeway speed it's just a vibration from the rear.
I stopped in a parking lot to check for a loose wheel and found nothing.
ideas?
TIA,
Vince
Old Jun 15, 2012 | 11:38 PM
ReBilld's Avatar
ReBilld
Check the rubber mounted carrier bearing in the middle of the rear drive shaft, all u-joints and the pinion bearing.
Old Jun 16, 2012 | 01:15 AM
compaddict's Avatar
compaddict
Will do! Thanks.
Old Jun 16, 2012 | 07:43 AM
Redneckmorton's Avatar
Redneckmorton
Sounds like it could be a slipped belt in one of the tires. Hard to spot. Put the truck in neutral on a level ground and slowly turn the tire while looking at it.
Old Jun 16, 2012 | 08:13 AM
91 Dually's Avatar
91 Dually
Tire... Possibly a warped brake drum?
Old Jun 21, 2012 | 08:32 PM
compaddict's Avatar
compaddict
Lumpy tire! Good thing it happened too. Found only one bolt left on my yoke! I was told to Loctite them on these trucks...
Old Jun 21, 2012 | 09:36 PM
Talyn's Avatar
Talyn
Glad you found it!
straightarrow
Jul 6, 2018 07:50 PM
jonathanpatr
Feb 22, 2017 07:18 PM
eberlestock
Sep 5, 2016 11:48 AM
tfs2403
May 12, 2012 11:00 PM
78truckpower429
Dec 6, 2003 12:05 AM
