all my gauges quit working so ive already replaced the 3 with aftermarket gauges but i need to know the ohms for my sending unit and which ohm set up on aftermarket will work with that range
i have looked into lots of things on it and took it to the ford place they "think" its the cluster which was $300-400 so much easier and cheaper to put aftermarket gauges
Consider the following.
Head temp, either electric or mechanical and the plumbing.
Oil pressure same deal.
Alternator charge, what will you do there?
Fuel gauge; the sender is part of the fuel pump assembly.
Speedometer, where and how will you pick up the correct speed indication?
Then you need to mount and light all them yet.
By the time you work all this out, $400 might look good.
I have Aux oil pressure and Trans temp electric gauges but all in my electronic stock dash works.
Good luck.
maybe its just weird they stopped working everything was working and my truck blew a head gasket so it was down for 5 days while i got that fixed then when it fired up none of the gauges worked except speedo and tach
