Sponsored by: Auxito
Truck Died While Driving on Highway
Old Jul 18, 2011 | 09:53 PM
richardfalco's Avatar
richardfalco
Hi all,
I have a 2001 F-150 (4x4) 5.4L V8 with 106,000 miles on it.
While driving this afternoon on the highway at about 55 mph my truck died and would not restart (no rough running or stumbling, it just shut off). After about 20-30 minutes of poking around under the hood, I thought I would give it one last try and it fired up and drove fine. Shut it down and started it up several times with no problems...
During my troubleshooting, I unhooked the battery for about 20 seconds (wish I hadn't done that). I didn't think that would clear the codes, but when I had it scanned, it showed nothing.
Any chance it was some kind of vapor lock (I know I'm reaching there)? The air temp was over 100 and I had about 1/4 tank of Casey's gas (which I believe is pretty high in ethanol).
Any guesses? I'm not sure where to start since it is running fine now...
Old Jul 19, 2011 | 04:28 PM
Dave G.'s Avatar
Dave G.
Sounds like a circuit breaker tripped, then reset itself after cooling down. Check your owners manual and see what is powered through one of those. Might have one that is getting weak.
Dave
Old Jul 20, 2011 | 12:16 PM
richardfalco
No mention of 'breakers' in the manual. Just fuses and relays.
Bad relay perhaps? I'm at a complete loss...
Drove it around town in the heat today and let it idle for a long time, could not duplicate the problem.
Old Jul 20, 2011 | 10:07 PM
keyul's Avatar
keyul
Had my old truck (98 f150 4.6L) do this a long time ago. Was just driving along and the motor shut off, started right back up and never did it again. I could never duplicate it. Hopefully yours will be like mine and that'll be the last of it!
Old Jul 20, 2011 | 10:59 PM
Dave G.'s Avatar
Dave G.
The breakers would be anything with a number in the 600's. Without a diagram, I can't tell you offhand if anything crucial runs through one of them.
Dave
Old Jul 21, 2011 | 12:38 AM
richardfalco
Ahh yes, found them in the manual. Only two CBs listed for my truck, one is "not used" and the other is for power windows and moon roof on a Super Crew (which mine is not).
Old Jul 21, 2011 | 01:04 AM
Tex1986's Avatar
Tex1986
I just had the same thing happen to me today. Turned out it was a loose battery clamp. I DOUBT that's your issue though. But had to throw it in just to be sure. Hopefully yours doesn't pop up again
Old Jul 21, 2011 | 02:30 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i had my '98 expedition 5.4 do this one time in the 11k i've owned it. one time issue i could never get to happen again. weird.
Old Jul 25, 2011 | 05:38 PM
PlatinumKanikas's Avatar
PlatinumKanikas
Mine did the same thing yesterday. I was driving and it just died. I tried starting it and it would start, but stumble and die. I waited about 30 minutes and tried it again and it started up fine. I haven't tried it since because I don't want to get stranded!
The engine code went away after it started up!
Old Jul 30, 2011 | 02:19 AM
richardfalco
Well, I guess I'm not alone...
Truck has been running fine since. It was almost like it got too hot and shut it self off. It was well over 100 deg that day.
jeepdude
15
Mar 26, 2017 05:46 PM
c2z4s9
51
Nov 9, 2016 07:15 PM
86F250_7.5_4x4
May 30, 2016 09:35 PM
DocRoche
Dec 2, 2015 04:16 PM
och
Sep 2, 2012 09:30 AM
