Sponsored by: Real Truck
Bad Turbo or What?
Old Jul 15, 2011 | 04:36 PM
RedDirtLandscaping's Avatar
RedDirtLandscaping
Bad Turbo or What?
We have a 2001 F250 7.3L that has about 334,000 on it. Bought it at 300,000, and from a diesel service shop, truck was running great and still for the most part is. It looks like the intake side of the turbo was replaced but not the exhaust side, or at least a new case was installed on that side. What we have going on now is that it idles very rough when first started, and will attempt to die. After driving a few blocks and flooring it for about 1/2 mile, it seems to do better, but still not great. Also fuel mileage is down around 12 MPG.
Aside from oil changes and air filter cleanings is there any more I can do for this truck? Should I change to glow plugs, relay, or anything like that?
I will provide any additional information and if a picture of the turbo would be helpful, I will get that as well. Thanks!
Old Jul 15, 2011 | 11:02 PM
FireMe's Avatar
FireMe
A turbo generally cannot make an engine run rough, but depending on the failure mode will usually just result in a lack of power.
The glow plugs are only there to start the engine when cold, and unless the temps are below 50 F where you are, are not a factor in your concern.
There are a variety of tests that need to be done on your truck, but just generally speaking given the miles you have and the very limited information you provided, my first inclination would be to suspect that the injectors are worn and are producing a poor pattern. Fuel atomization is critical on a cold diesel, and becomes somewhat less important as the engine warms. The symptom you describe, poor/rough running cold which improves as the engine warms up, is very typical of an engine with worn injectors.
Again, this is just a guess based on your information. You need to get your truck to a competent diesel tech for a thorough going-over.
Old Jul 16, 2011 | 08:23 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You need to get the codes read and let us know what they are. If there was someone close to with a AE, they could do a few test to see what is going on with the injectors.
I would think the injectors may be getting week or the UVCH may be loose and not getting a good connection. Make sure none of the wires going across the VC are chafed and grounding out.
Old Jul 16, 2011 | 12:41 PM
RedDirtLandscaping
Sorry for asking, but I'm not familiar with the short hand, such as UVCH and the VC. Also, I realized I have never changed the fuel filter, how much of an effect would this have?
Old Jul 16, 2011 | 12:47 PM
ToMang07's Avatar
ToMang07
If the fuel filter is plugged up... huge. Plus you need to dump any acumulated water out.
http://www.guzzle7pt3.com/ffilter.php
UVCH = Under Valve Cover Harness
http://www.powerstroke.org/forum/7-3...r-harness.html
VC = Valve Cover.
VERY Helpful mods/maintenence site: http://www.guzzle7pt3.com/index.php
Old Jul 17, 2011 | 08:57 AM
RedDirtLandscaping
Changed the fuel filter, little effect, seems to start better.
Still wanting to die in reverse, but it just came back from a transmission shop who checked out the transmission, and torque converter.
It is reading 2 codes from the programmer, P1249 and P1211. The program is set to extreme, should I back it down?
Old Jul 17, 2011 | 09:06 AM
ToMang07's Avatar
ToMang07
P1249{3}
Waste Gate Control Solenoid
P1211{2}
ICP Pressure Is Above/Below Desired, Faulty IPR Valve
P1211{1}{3}
ICP Pressure Uncontrollable, Pressure Above/Below Desired
Old Jul 17, 2011 | 09:36 AM
RedDirtLandscaping
Originally Posted by ToMang07
P1249{3}
P1211{2}
P1211{1}{3}
Right, what to do about those? Been reading on the forum that the P1211 is not a major concern, and that the P1249 can be a variety of things from the solenoid to simple vacuum tubing. Any suggestions?
Minuteman3
2015 - 2020 F150
22
May 31, 2016 10:32 PM
RedDevil460
Mar 11, 2015 02:13 PM
wagners
Oct 9, 2012 08:11 AM
kpjr
19
May 3, 2010 08:01 PM
Fordson1
Feb 11, 2007 08:59 PM
