Engine running kinda wierd. Need a direction to run...
Hey guys. My 7.3 is running kinda weird and somewhat difficult to explain. Sometimes I can feel a high-frequency, low pitch vibration while the engine is at idle. Ambient and coolant temp do not seem to cause any difference. I brake torqued the truck in both forward and reverse and observed the engine. I do not believe that I have a bad motor mount, but I'm not ruling it out just yet. I performed a contribution test with my Taskmaster and it passed no problems. Any other ideas would be appreciated!
Thanks!!
Aaron
Thanks!!
Aaron
Thanks for the reply. I was JUST thinking about checking the front dress stuff on my way home last night. I can only feel it, I have not heard it. I will have to check the turbo, but wouldn't I feel the turbo go out of balance as it spools faster not slower, as well as hear it bounce off the housing?? Also, if the turbo shaft was moving around wouldn't it be passing oil thru the seals causing excessive smoke and/ oil dropplets in the exhaust???
Aaron
Aaron
