How far should the fan be from the radiator?
Old Mar 19, 2003 | 01:35 PM
proeliator's Avatar
proeliator
For maximum cooling effectiveness? I've seen them as close as 1" and as far as 6". Need to do everything I can to maximize my cooling potential, and as my fan is 4.5" from the radiator I was wondering if there were benefits from moving it 2" closer. Thanks.
Old Mar 19, 2003 | 03:10 PM
Ultramagdan's Avatar
Ultramagdan
I think the more important thing is to have a good fan shroud. So long as the fan is pulling air through the radiator, it shouldn't matter if it's a couple of inches one way or the other so long as the shroud is there. Just my opinion.
Old Mar 19, 2003 | 03:29 PM
proeliator's Avatar
proeliator
your 100% correct, of course. I'm building my own shroud, but thought I'd determine optimum fan placement before I tacked the sheetmetal together. I talked to a tech at flex-a-lite and they said that without a shroud the closer the better (leaving a minimum of 1" for engine flex), with a shroud it doesn't matter provided the shroud fits tight and the fan is at least 50% inside the shroud housing. I think I'll pick up a 2" spacer which will put my fan 2 1/2" away from the radiator and build the shroud accordingly.
cowdog86
Feb 4, 2017 10:28 PM
danlee
Dec 11, 2013 09:26 PM
puroford
Jul 17, 2013 04:40 PM
SilverSport
Nov 14, 2006 06:43 PM
Dan-79F350
Aug 25, 2001 08:51 AM
