Correct intake for GT40 headswap
Old Apr 4, 2011 | 10:30 AM
theoriginalscion's Avatar
theoriginalscion
I installed a pair of Gt40 heads and wanted to confirm that I can run original intake on my 351W?. I,have a very large vacum leak that is keeping truck from running. I suspect somthings going on at lower intake.
Old Apr 4, 2011 | 11:09 AM
lew52's Avatar
lew52
The original 351 intake will work.....Lew
Old Apr 4, 2011 | 11:13 AM
Homeslice's Avatar
Homeslice
Stock should be fine. Did you use the cork end gaskets on the intake when you reassembled? What are the symptoms. Will the truck not start or will start and not stay running?
Old Apr 4, 2011 | 06:40 PM
Jozey's Avatar
Jozey
the heads are all teh same from a 302 and 351,teh only difference is deck height which the 351 is taller and uses its own intake
Old Apr 5, 2011 | 09:32 AM
theoriginalscion
I can get truck to run/start by holding throttle to floor,and i have to give gas to contiue running. I have no vacum while cranking, or tryingtorun without a lotof throttle.
I used felpro 1250 intake gasket set.perhaps not correct choice.Or incorrrectly installed. I will have to dissaseble and inspect.
A few more clues,
Spark,timing,fuelpressure,pulse, compression, good.
97f250HD 351W gt40heads, stocklowerend,ported upperand lower intake,mustang off road headers, my custom exhaust. Egr is intact, eliminated allthe other emmissions crap.
Old Apr 5, 2011 | 09:46 AM
rla2005's Avatar
rla2005
With the throttle to the floor the TPS value should be at/near maximum output. The PCM will normally shut off the injectors when cranking the engine in this scenario. This is a built in feature to clear a flooded condition. You might want to check the TPS output signal.
Did you leave the MAP sensor hooked up? Assuming this truck is Speed Density....
Old Apr 5, 2011 | 09:53 AM
Jozey's Avatar
Jozey
A few more clues,
teh felpro 1250's are a great gasket,i uese those alot,when you hold the throttle to the floor and it starts that sounds like a fuel issue,if the injectors are spraying to much(stuck open ailttle)the will give you a hard time starting it,when you holt the throttle to the floor before you crank it,that will not spray the injectors till the motor fires.are you sure you have the injectors clips on the right injectors?when you get it started,does it sound like it misses when your keeping it running?
Old Apr 5, 2011 | 01:23 PM
theoriginalscion
Yes injectors are correctly routed, i have tryed two sets of injectors. the originals that i installed new screens and o-rings, and a junkyard set to rule out bad injectors. fuel pressure's right on money, and I do have gas in it.
I've also had a Modis hooked up. No codes, and senor data is normal.
I have a occasional miss, but probably more related to the fact that i need to fine tune timing adjustment. I followed thread on site here about setting base timing to 10* before. But I need to get truck running and idleing correctly to set timing
Yes truck is still speed density,I have not sourced all the parts needed yet to do mass air flow conversion.
I know I'm missing somthing stupid. The truckran like atopbefore i swaped out heads and redid everything.
Also electical is good.I have 2/0 power and ground cables for battery. and numerous grounds dasiy chained together. 160 amp alternator,plus a lot of other goodies i swaped in.
Old Apr 5, 2011 | 01:50 PM
rla2005's Avatar
rla2005
The engine will never fire under this condition. If you hold the throttle all the way down you can crank on that *****' until the battery dies. The PCM will not turn the injectors on.
If the OP has to hold the throttle all the way open to "get it to run" something is wrong with the TPS circuit. A simple check with a $5 voltmeter will prove me right or wrong.
Old Apr 5, 2011 | 02:29 PM
Jozey's Avatar
Jozey
if the cylinders have to much fuel in them from say leaky injectors(like i stated as a possible problem) and if it wont fire cause of that then yes,if you hold the throttle to teh floor and crank it, it will not fire the injectors so the excess fuel in the cylinders can fire and teh engine can start.
Old Apr 7, 2011 | 05:23 PM
theoriginalscion
Well I looked at TPS circut. Been busy fixing other peoples crap boxes.
circut 351-VREF 5volts
355-tps input-0.912voltsclosed throttle, smooth progressive voltage rise to max 4.26volts at WOT.
359- sensor signal return.- Zero Ohms resistance. All grounds show no resistance. Sensor signal return circut good to PCM.
Also all PCM grounds good.
So I can run the truck intake,which i was pretty sure about. Andthe 1250 gaskets are okay to use.
Back to my original problem, lack of vacumn. I just smoke tested intake.nothing.If I have a lower intake gasket leak?. I cant see it and no smokes coming out.
I would like to thank all those who have responded.I need some good input from those who know these trucks. I'm dying to get this `truck`running. Its my first V8 ever.
Old Apr 7, 2011 | 06:40 PM
Homeslice's Avatar
Homeslice
TPS looks ok, could bump it to .99 closed but nothing that would cause your problem. Do you have a vacuum gauge to test how much vacuum you're drawing? How does it run when you have the throttle down? Is it smooth or is it skipping or popping or anything?
As far as the heads go, are you running roller rockers with them, if so, how did you set the valve lash?
Old Apr 10, 2011 | 02:22 PM
theoriginalscion
Opp's, I used rocker arms from gt40 heads. I picked heads up at a U-pull yard for $40..came off early 97 mountenier.
So I should swap out rocker arms from the old E7 heads??
Old Apr 10, 2011 | 03:42 PM
Jozey's Avatar
Jozey
are they the roller rockers?if so i would leave them,they are better than teh stamp steel ones
Old Apr 10, 2011 | 07:00 PM
Homeslice's Avatar
Homeslice
If they were stock, I don't believe the mountaineers came with rollers. Only the Cobra motors.
When you installed the heads, did you torque down the rocker arms to the right specs? The reason I say that is if you have them torqued too tight there could be too much pressure on the valves which could lead to problems. Also depending on how many miles on the motor the valve springs could be tired.
