Lift Kit and Tire Questions
Old Mar 1, 2011 | 11:49 AM
dad2nick's Avatar
dad2nick
New to this forum. Posted this on Super Duty Forum also. Posting here in case others don't check that forum. Thanks.
I just ordered a 2011 F-350 Crew Cab Diesel 4WD from the factory to replace my current 2000 F-350 Super Cab 4WD (now for sale). I ordered the truck with the 3.55 locking rear axle and 275 tires mounted on 20" rims. The truck will be used mostly for towing my old Dodge Power Wagons (approx. 9,000 lbs with trailer).
QUESTIONS:
I would like to install the CST or Icon front stabilizers and shocks. Also considering a 2.5" lift from CST or Icon. Has anyone got pictures and experience using these products on a 2011 F-350 Diesel?
Does it make any sense to mount the 2.5" lift kit with the stock wheels or should I wait until I wear out the first set of rubber and have the funds to upgrade to larger tires and wheels?
I will not be mounting anything extreme since this is primarily a tow vehicle. What size tire and wheel would give me the best fuel economy while towing without loosing pulling power in the mountains, etc.?
Finally, if I change the wheel/tire size is there any way to recalibrate the shifting points in the automatic transmission without installing a chip? Does the truck's computer recalibrate automatically? Are there any chips designed for towing performance that do not violate factory warranty?
Thanks in advance for any help and advice.
<!-- / message -->
<!-- controls -->
Old Mar 1, 2011 | 02:37 PM
cummins cowboy's Avatar
cummins cowboy
the back is approx 2" higher than the front if you do a 2.5 "leveling lift its going to make the front higher than the back with no load, hook up your trailer and your going to be sagging big time.
Budlight592
6.7L Power Stroke Diesel
Apr 9, 2014 08:45 PM
seminaryranger
Jul 2, 2013 10:20 PM
dad2nick
Mar 3, 2011 05:41 PM
KING
Apr 8, 2008 07:27 AM
kpd73
Mar 7, 2006 10:19 AM
