tail light help
Old Feb 8, 2011 | 08:39 PM
davek336's Avatar
davek336
tail light help
I changed my tailights today but the runniing lights dont work, the blinkers and brake lights do...anyone have any info???
<!-- / message -->
<!-- controls -->
Old Feb 8, 2011 | 09:21 PM
One79one71's Avatar
One79one71
Did you verify wich wire runs what before you wired it up?? I know i put led taillights on my 79 stepside that had 3 wires stock, but the new lights needed only 2 and a ground...maybe that brown wire was a ground...I know 1 wire runs the turn/brake on mine and the other the tail. Use a testlight to check when u get power to wich wire on your trucks wiring if u havent done that already.
Old Feb 9, 2011 | 11:48 AM
Flyn66dtmn's Avatar
Flyn66dtmn
the slicks have a body ground on the tail lights so that is prolly not your problem. there are three wires that run back. tail lights, and left and right brake and turn signal. if neither bulb comes on when lights are turned on then the lead coming in is prolly not working. check your fuse. you didn't say what year but the 65 and 6 have a taillamp fuse in the fuse box. check your bulbs, they need to be a 1157 dual filiment bulb. make sure both filiments are in working order. if all works out there then you should test your wires at the back to make sure the juice is running to the lamps , if not then your problem is elsewhere. was they working before you changed them.? buy the way what did you actually change. the bulbs or the entire unit? dutch
LEO56F100
85
Mar 28, 2017 10:40 PM
FredsTow
Large Truck
Sep 15, 2015 01:20 PM
David1986
6.7L Power Stroke Diesel
Apr 22, 2015 07:47 PM
Econogirl
Aug 21, 2010 08:56 PM
4rdfvr
2004 - 2008 F150
Apr 4, 2010 09:32 PM
