Wife asked....
Wife asked....
well.... she's complaining about the ford gold remote start not staying on very long to warm 05 6.oh Ex up in the am...
I told her it was set for 10 minutes when they installed it IIRC...
of course she timed it this morning says it only runs for about 3 minutes...
is there a simple dial I can change the idle length ?
(I know idling is not some people's cup o' tea,
but my happiness is directly related to her's !!!
if you get my drift !)
Thanks in advance !
JB
Thanks in advance !
JB
I had a aftermarket remote which had a pin setting in the box behind a panel... Removed panel set it to 15 minutes and was good to go... Never seen one where the remote sets the duration.. But could be... My old one also had a setting that would auto start the truck every 2-3hrs and run it for 15 minutes to keep it from freezing if it gets to cold...
Your best bet is to find the module most likely under the the dash drivers side... Get a MFG name and model and I'm sure you will be able to find the manual on line... One of the biggest mfg is direct electronics.. Not sure if ford actually makes there own... or if its a dealer installed item...
Max for the ford gold is ten minutes.
I also have this in my truck, I have done so much research trying to find info on installation and options on this remote!! nobody can give my much info
found out that it is made by power code systems
there is some threads here about it do a search for ford gold or power code
This is my half arsed attempt at helping you.
I googled a few things and found most people that are having trouble with this system are directed here.
Car Alarm, Car Stereo, Mobile Video, and Cruise Control Info for Installers
A hand full of people from other forums said the manual can be downloaded there.You will have to register to get the instructions,Which I did not do,So I can't tell you for sure there on there or where to navigate too.I hope this aleast gets you started.
This place is also supposed to have every remote start manual.
http://techservices.codesystems.com
Make sure you get this fixed ASAP!!!!Because remember..."Happy wife Happy Life"
