Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Midland Hy-Power brake booster
Old Nov 9, 2010 | 03:08 PM
F250racer's Avatar
F250racer
I have a Midland "Hy Power" hydrovac booster from a '59 f600. I'm trying to use it on my '59 f250 but not sure how it works. Does anyone have a diagram for it? I took the main cover off and the diaphragm is in good shape.
Is there supposed to be brake fluid on the inside of the diaphragm(side between the diaphragm and the brake lines)? With the diaphragm off, spring/rod removed, I applied air pressure to the brake inlet port, I get air out the outlet port as well as the hole where the diaphragm rod goes in.
Any info/diagrams you could give me on this unit would help, just can't find a lot of info on it.
Also on the back there is a square head plug, is this the reservoir for brake fluid?
Old Nov 9, 2010 | 05:36 PM
rbaker6336's Avatar
rbaker6336
There is not suppose to be any brake fluid in the vaccum chamber,the master cyl is the fluid reservoir
Old Nov 9, 2010 | 11:35 PM
85e150's Avatar
85e150
Why would you use a hydra vac system vs. a standard vacuum assist master cylinder? Seems a needless complication of your brake system.
That, and you could have a dual master set up with the standard master type.
Just a thought.....
Old Nov 10, 2010 | 12:14 AM
F250racer's Avatar
F250racer
I already had this unit(I had a '59 f600 parts truck). I got it all put back together and installed in my truck, seems to work pretty well. I haven't had it on the road yet though.
Maybe later I'll upgrade to a regular boosted MC, just working w what I have for now to get the truck finished and on the road.
dhglaser
21
Apr 29, 2022 07:07 AM
maddogjohnson
Mar 11, 2017 10:28 AM
LCarter69
Aug 5, 2016 07:38 PM
brdfrd
Large Truck
Jun 27, 2016 08:53 AM
65fordguy
33
May 3, 2016 07:41 AM
