F150 4 inch lift springs
Could someone with a 4 inch lift take a measurement from the bottom of the fender to the center of the hub and post. I`m trying to figure out if my springs are up to par. Every single front end part on my truck has been replaced except for the springs and I`m not sure it rides like it should. I have dropped pitman arm, drop trac bar bracket, drop control arm brackets, nitrogen shocks and a steering stabilizer. All eurathane bushings. I feel like I`m getting a little bump steer. I`m running 33 inch bfg`s. I`ll measure mine in the morning and compare. Thank you
