Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
vin help
Old Oct 30, 2010 | 10:55 PM
73supercamper's Avatar
73supercamper
vin help
i just bought this truck and would like help decoding the vin and data plate. i do not have the info from the data plate yet but the vin is F60BK520244. thank you
Old Oct 31, 2010 | 01:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F60 = F600 (gas).
B = 262 1V I-6.
K = Kansas City MO Assembly Plant.
520244 = 1964, assembled March 1964.
Old Oct 31, 2010 | 10:36 AM
73supercamper
just wanted to say thank you and would you br able to do the data plate when i get the info?
Old Oct 31, 2010 | 01:53 PM
NumberDummy
Abso-tutly.
Old Nov 1, 2010 | 06:03 PM
73supercamper
ok i got the data plate info. it reads: WB Color Model Body Trans Axle 174 J F602 181 F F8 Max G.V.W LBS Cert Net H.P. RPM D.S.O. 20000 132 3600 452235
Old Nov 1, 2010 | 06:06 PM
73supercamper
sorry that didi not show up how i typed it in. WB 174. Color J. Model F602. Body 181. Trans F. Axle F8. Max G.V.W. LBS 20000. Cert Net H.P. 132. RPM 3600. D.S.O. 452235 hope his one shows up better or that you can at least make sence of it
Old Nov 1, 2010 | 08:02 PM
NumberDummy
ok i got the data plate info. 174 J F602 181 F F8 20000 132 3600 452235
Makes sense...to me.
174" Wheelbase.
J = Rangoon Red.
F602 = F600 (gas), 20,000 lbs. GVWR
181: 1 = Light Gray Crush Vinyl & Light Gray Rib Pattern Vinyl / 81 = 81A Standard Cab.
F = Borg Warner T-98 4 Speed Manual Transmission.
F8: Eaton Model 13802 2 Speed Rear Axle / 6.33/8.81-1 / 15,000 lb. Rear Axle Capacity.
20,000 lbs. Gross Vehicle Weight Rating.
132 net HP @ 3,600 RPM (262 1V I-6).
452235:
45 = Davenport IA Ford District Sales Office, where the original selling dealer ordered the truck from.
2235 = Domestic Special Order number. Your truck was special ordered by the original purchaser, not "bought off the lot."
