school auto project 300 I6 (4.9L)
I have owned my truck for exactly 1 year now
it is a 1985 f150 4spd manual, regular box and cab 158000km (98750 miles)
a little background on what I have already done ( to the engine only)
new valve cover gasket
new oil pan gasket
5 oil changes and filter changes over 400km to flush all the crap out (until oil stayed gold)
o2 sensor replaced
coolant temp sensor replaced
new fuel filter
all new spark plugs, wires and distributor + rotor
K and N air filter
have a new thermostat to install this weekend.
well in 3 months or so I will be going into auto class again and as this is my last year with acses to a good shop I want to upgrade the engine.
like a full re build and upgrade.
I want the engine to get better mpg.
have more torque and hp too
this is my every thing truck as I only have 1 vehicle it is in city, highway and off-road (there all about the same in amount)
as you guys are the experts I want to know what I should do for upgrades and places to get them (money is around 1000-1500)
I want to keep the same carb for now (1brl stock carb) as I like the air intake it has (unless there's are more fuel efficient carbs- I want better mpg) (I will know tomorow my current mpg)
my mechanical aptitude is well OK.. I want to learn and my auto teacher has been a mechanic for 35 years so he can help lots (I dont think there is a single thing he dosent know about older cars)
summed up
what should I install for performance parts that will help me get better mpg?
thanks for all the help and sory for the long post.
That requires replacing the Analog Intake & Exhauste Manifolds w/ an Offenhauser "DP" Intake, Holley 450 Economizer & a Header.
That's about all you can do w/ the Funds you stated you are willing to Spend.
for the fun of it, lets say I was willing to spend another 2k brininging it to around 3.5k total
what would the next upgrades that would give me the biggest gains be?
what are people getting for milage with there set ups (bolth stock and performance) and there engines hp and tourque please.
I will post my milage when i get home and see how far I went on this fill up.
Mallory Distributor & MSD box Electronic Ignition set-up.
Balanced & Blue Printed, w/ a Minimal Porting & Polishing job.
Find an All Steele Crank & go for a Bore & Stroking job as well.
Mileage depends on how much a Lead-foot you are, but 20-25mpg can be achieved.
You have an 85 so its got the feedback carburetor on it. This setup is pretty problematic if it isn't working right and gives you horrible performance and gas milage. The best bed would be to totally get rid of this and setup and switch over to a duraspark ignition system. If you do some seaching on here you can find tons of information on it. It is very simple just a plug and play. You just need to get a engine wireing harness from a pre 84 year 300, ignition module that mounts on the fender, different coil(MSD Blaster II coil works great), and duraspark distributor.
First thing you should think about is if you have to pass any emissions test where your from. Doing some of these mods won't pass emissions.
If you look at my signature I've done all the about stated upgrades and it was amazing the difference. Like have a totally different motor in there. My gas milage before I did any of these upgrades I was getting 8-10 it was horrible. With everything now I get 13-14 city 16-17 highway pretty consistantly and have tons more power! I don't have any real numbers on my motor but from everyones estimated with there similar builds your looking at 200-230hp and 300-330trq. Doing these performance upgrades make it seem like you have two of these motors in there. There are alot of knowledgable people on here and hopefully some others will chime in with some more advice.
well I figured my mileage and well its 10.8mpg a combo of highway, city and dirt road.
this is complete **** compared to what I was getting I was getting 15 at the beginning of September, pretty much doing the exact same driving.
I even got a K&N air filter (supposedly helps) dident think my mileage would go down after switching to a better filter and if not better at least a clean filter.
I think there might be a problem
we will see after I replace the thermostat that I am almost positive is stuck open.
going to be a realy tight winter if this is my mileage befor winter tires and winter gas
would there be any ill effects if I switched over to the "Edelbrock 1403 500cfm carb" suggested by "coolguy1419" with my stock set up? like I know I would need to adjust it but it would be adjustable to not be running rich right?
would my stock air cleaner work with this?
